Speaker wire
Old Apr 17, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Speaker wire
I just picked up a JBL 360w 4ch. amp. This is my first amp ever and I insist on installing it myself... how else will I learn? [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
I already know hot to power, ground, and get signal to the amp. My question is, do I need to run speaker wire? I've searched for "wire" and "wiring" but the only topics that show up involve power wire & signal wire. So, is everyone using the factory speaker wiring? What's the easiest way to tap into it?
Old Apr 17, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
I would always recommend running your own wire....at least 16 gauge to speakers. Good luck with your wiring.
Old Apr 17, 2002
PESTLNC's Avatar
The rear speakers will be easy, but what path should I take for running wire from the amp to the front speakers. I'm assuming I shouldn't follow the power wire.
Old Apr 17, 2002
slikor's Avatar
slikor is an unknown quantity at this point
to get speaker wire to the front speakers from your amp, it would probly be best to run it on either side of the car on the door kick panels or through the center console cover, whicever is furthest from the power wires.
Old Apr 18, 2002
mohawkboom's Avatar
Running it with your power wire is fine..DOn't worry about that.. it's a high voltage signal with decent amperage..you won't get any noise..
Cheers
Mohawk
Old Apr 19, 2002
PESTLNC's Avatar
So, power, remote, and speaker wire down the passenger side of the car, and RCAs and speaker wire down the driver side would be good?
Here's what I have now:
PG Shielded TP RCA Cables
4GA Power & Ground Wire
12GA Speaker Wire
16GA Remote Turn On Wire
Sounds good?
mrwhos
Aug 11, 2015 02:03 AM
carid
Aug 8, 2015 05:05 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
