Headlights burning out
Old Jan 9, 2010
warbirdlover's Avatar
warbirdlover is an unknown quantity at this point
We've had our 2002 Honda Civic 4-door for over six years with no problems. In the last year we've replaced the headlights (both) over a dozen times. Left will burn out then the right. Always alternates. One side never burns out twice in a row. Bulbs have been changed by repair shops and myself. I'm always careful not to touch the bulb. The fuses are fine. We've also tried bulbs from different makers with no results. I just changed the left side last week. Now the right side has burned out. I checked the bright lights and no brights on either side. What the f**k is going on? Anyone else have this happening?
The plugs are not loose either and the bulbs ARE burning out. The fuses are the correct ones and are good. Voltage regulator problem?
HELP!!!
Old Jan 9, 2010
amatias's Avatar
amatias is an unknown quantity at this point
Re: Headlights burning out
sounds like an electrical problem. could be a bad alternator, try testing your alt and ask gearbox, he should know.
Old Jan 9, 2010
well next time you can try a long life bulb, supposed to last double what a normal bulb should. but something is wrong. have you checked voltage at the bulb connector with the car running?
Old Jan 10, 2010
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
If the bulbs look like silver misshapen Christmas ornaments, some contamination such as oil or acids from fingers is getting on them and causing them to blow up and burn out.
If they look like regular burned bulbs with a broken filament, it is probably an overvoltage especially if the headlights look really bright. Do the hi beams burn out too?
Overvoltage can be caused by a number of things, most commonly a fried / failing relay which fails the wrong way, or an alternator going bad.
As suggested before, get a voltmeter and shop manual and test voltage with the car running and under load in both engine cold and engine warm conditions under load.
Old Jan 10, 2010
The bulbs are not mis-shapen and not being touched. And the brights go before the dims on the last change.
My next question is ... if the voltage regulator or alternator are the problem why don't the headlight fuses blow before the lights fail? The fuses are the correct 15A and are good. What good are fuses if they don't do what they're supposed to do?
Old Jan 10, 2010
your alternator may be pushing higher voltage like 15v+ but not enough to blow fuses. if the wiring is able to move that much power, it will without a fuse blowing. this can damage many components in the car so i would get the alternator checked asap. you can even measure it yourself with a voltmeter on the battery while car is running. it should be around 14.2v max.
Old Jan 10, 2010
CraigW's Avatar
For certain I would check the voltage output, make sure it is not staying high.
Also make sure the bulbs are not being shaken/jolted or somehow moving when in use, that would shorten their life.
I remember working on an older car once over-charging, it affected the smaller bulbs.
Have any of your smaller lamps failed while these headlights are going ?
Old Jan 10, 2010
CraigW's Avatar
I remember working on an older car once over-charging, I recall it affected the smaller bulbs
Have any of your smaller lamps failed in the time that the headlight issue has been occuring
Old Jan 10, 2010
Like I said, we've owned this car for over 6 years and only this last year has been the problem. So "shaking" isn't the problem. Will get the alternator (and regulator?) checked. Thanks.
Old Jan 15, 2010
You guys are GOOD!! It WAS the alternator putting out too much and is costing me $580 to fix. But problem solved. I wanted to make sure others with this problem saw the fix. Thanks!!
Old Jan 16, 2010
electric130's Avatar
thanks for posting back an update.
Old Jan 16, 2010
04 Honda Civic's Avatar
What are you paying $580 for? A new alternator? Your getting ripped off..
Old Jan 16, 2010
even a HO alt is cheaper than that
Old Jan 16, 2010
i "paid" around $500 for my napa alternator installed, but i had extended warranty those are a pain to install on the newer civics and im glad i didnt have to do it.
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
Bricoleur
Sep 9, 2015 12:23 PM
