Boxing Day Speakers - Worth it?
Old Dec 24, 2009
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Hey,
So ever since I've gotten my new deck, I've noticed that a lot of the sound seems to come from the rear speakers, and not enough from the front. The balance is centered on the deck but it still sounds uneven. I'm thinking maybe replacing the OEM front speakers will help with the sounds.
Are these speakers worth it?
http://www.futureshop.ca/catalog/pro...ing&langid=EN#
They're a boxing day sale - regular $69 for $39 for the set.
OR
These ones:
http://www.newegg.ca/Product/Product...82E16882647039
Regular $109 for $39
The ones from Future Shop can be picked up in the store on Sunday, and the Newegg ones need to be shipped (and probably bought soon, not sure what their stock is like).
I wasn't really planning on upgrading my speakers at the moment, but I was looking through some of the Boxing day sales and noticed some speakers that I could actually afford... so now I'm thinking about it.......
Opinions? Better deals?
EDIT: I never even thought to check if they would fit. What size will the front doors take in a 02 LX Coupe?
Old Dec 24, 2009
lowlife9's Avatar
Re: Boxing Day Speakers - Worth it?
i don't think that will help it sounds like the head unit how about adjusting it more to the front to even it out.it also doesn't help the front speakers are on the floor i would recommend putting tweeters up top were the stock ones would go on the side mirrors or cutting holes in the door panels like i did.and i dont think 6×9s are going to fit in the front.
Old Dec 24, 2009
Awjvail's Avatar
I've got the tweeter pods up on the sail panels and ever since the HU has been installed, they don't seem to be producing much sound anymore either.
I have to turn it up really loud in order to hear the highs because they're coming from the back of the car pretty much. Otherwise, it sounds muffled.
I dunno.. maybe I have to screw around with the settings some more. Should I try new tweeters before I try new speakers?
Old Dec 24, 2009
lowlife9's Avatar
are your highs amplified if not you mite have damaged them turning the volume up so loud i did that with a set of titanium mb quarts.
Old Dec 24, 2009
Awjvail's Avatar
Um... I don't think so...
It has been doing that ever since I got the deck installed, so unless they blew them while the car was in the auto bay getting it installed, they aren't blown..
Old Dec 24, 2009
lowlife9's Avatar
well theres your problem you need to take the unit out and check the wires make sure they didn't half *** the connections they should be shrink wraped. you really need a amp.
Old Dec 24, 2009
BlueEM2's Avatar
Whachya lookin at?
Maybe they did not hook them up properly. I have stock tweeters and they are good enough for highs, my sound is great. Alpine HU with stock all around except 2 subs. I would recommend upgrading the tweeters or making sure they are hooked up properly.
Old Dec 25, 2009
hopefully they did not just "tap" the tweeters to the front speakers. that will cause all sorts of issues (unless you have components that are designed to work together). i have my tweets on deck power and they are very good. my other 4 speakers are amped with the tweeter parts pointed to the floor so i dont have too much treble. the front speakers dont really make much sound being so low in the door, so maybe try fading it forward. its hard to find the problem without listening to it and knowing the setup exactly.
x2 on the wiring. i did a crappy job on mine the first time and after a while i would notice static and not very good sound. redid the wiring and much better. same for the front door speakers, the spade terminals would keep getting corroded so i finally just wrapped the wire directly to the speaker and sealed around it with butyl tape to keep water out.
Old Dec 25, 2009
Awjvail's Avatar
Well I really hope they didn't do a half assed job on the HU install.
They're a local company that specializes in auto sound and has been around for years, so I'd hope they'd know better than to just connect the wires and not shrink wrap them.
The install itself doesn't look as fit and finished as I was hoping for... the mounting bracket does not sit quite flush with the rest of the panel but I had a look at some other peoples cars and they appear to be the same.
How can I tell if they didn't install it properly?
BTW, in case it matters, my HU is a JVC KD-R800.
http://www.futureshop.ca/catalog/pro...&test_cookie=1
I love the deck, it's just the sound quality of the front speakers + tweeters that I've got an issue with. The sound was great and very balanced with the stock HU.
P.S. - I was just wondering... my friend has a 2005 SI sedan (Canadian) (basically an EX), and he doesn't have the tweeter pods at the sail panel and I do in my 02 LX coupe... how coem?
Old Dec 25, 2009
maybe they were added? idk, tweeters were only supposed to come on EX models but canada always has weird differences. the "ex" tweeter panels and tweeters should fit any coupe, just not sedan.
thats a nice jvc too. are you basically running that deck and some aftermarket speakers? no amp? it would help if you exactly describe your system. you also need to play a bit with the jvc sound settings. almost any deck will sound bad when you first turn it on. gotta tune it to your listening style.
Old Dec 25, 2009
if you have stock speakers, and you are wanting to just get new ones and run them off aftermarket deck, i would look into the cheaper $40 a pair pioneers that walmart has. i think theyre around 35w rms max so they are lower power and a great match for just hu power (around 20w rms per channel). they will sound better than expensive higher watt speakers. if you go with higher watt speakers like 60w rms+ then you need an external amp to power them.
Old Dec 25, 2009
Awjvail's Avatar
The only thing I've got done is the deck. Nothing else.
I've had it since July and the only other mod I've done to it is take the dealer decal off <_< Hopefully once it's paid for (6 months-ish) I'll be able to afford more expensive mods.
I don't think they were added... I bought my car from a middle aged woman who used the car as a commuter and didn't do anything to it whatsoever.. I doubt she'd add tweeters.
The car doesn't specifically say LX on it anywhere but the VIN shows LX and all the features show LX (no sunroof, crappy plastic hubcaps, etc.) so I'm assuming it is an LX.
Old Dec 25, 2009
lowlife9's Avatar
it sounds like the person that had it before you just connected the tweeter to the existing stock speaker that could definitely damage it at high volume.
Old Dec 25, 2009
Awjvail's Avatar
I'm 99.9999% sure that the tweeters were factory...
The person I bought it from was the original owner and she never did anything to the car aside from maintenance, let alone install tweeters.
Besides - they worked fine before the HU was installed last week...
How can I tell whether the deck was incorrectly hooked up to the tweeters?
Old Dec 25, 2009
plastics's Avatar
plastics is an unknown quantity at this point
MTX speakers are crap..don't buy them, waste of time.
Get a set of decent separete speaker (Tweeter and base in 2 places) replace the OEM speakers set and should sound good
Old Dec 25, 2009
i really dont see how adding aftermarket deck would change anything, you prolly should not have seen a difference.
roverben
Jan 21, 2019 05:16 PM
danace99
23
Jun 28, 2015 08:49 AM
werdnahall
May 17, 2015 11:37 AM
