Electrical problem, HELP!!
Old Nov 4, 2009
drjay9051's Avatar
drjay9051 is an unknown quantity at this point
So I bought my first Honda, an 01 civic ex. 130K miles. No problem for six months. Go to start car this morning, no go! I have horn but no lights. Turn key nothing however when I turn off key the gauges will buzz and jump around for a second or two. Short? Any ideas? I have heard electrical problems are expensive. Money is tight. I have checked battery, no problem. Again I have strong horn, no lights and no start.
Where do I start aside from my local dealer> Also bought car for about 5K at what point do I junk it? If the repair is sasy $1,000 am I throwing good money after bad.
Thank you
J
Old Nov 4, 2009
Re: Electrical problem, HELP!!
could be starter went bad if youre sure its not the battery.
Old Nov 5, 2009
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
Might be the starter my bet is on the key ignition.
Old Nov 5, 2009
electric130's Avatar
what is the voltage on the battery with a multimeter?
Old Nov 5, 2009
drjay9051's Avatar
Voltage reads 10 volts. Also of interest, when I turn on the lights with key out of ignition I do not get lights however the gauges do the little jump I described for about three seconds. Sound serious??
Old Nov 5, 2009
i would try to jump start or charge the battery first. 10v is very low. probably low enough that your battery is toast and will need to be replaced.
Old Nov 5, 2009
drjay9051's Avatar
Electric 130: THANK YOU!!
I jumped it and it started up. I suppose I will get a new battery. It's the originalk and I guess at 130K and 2001 its time.
Whenever I have had a bad batterty in the past I lost horn and lights. The horn lead me top believe battery was OK. I missed the obvious, jump start. Im a bit confused, why were the gauges jumping and buzzing with a low battery? I have never seen this in my other vehicles. Again, thank you I was ready to have it towed 40 miles to the Honda dealer.
J
Old Nov 5, 2009
when the voltage gets low enough, crazy things happen. i really wouldnt really expect much more than 5 yrs or 100k out of an OEM battery. especially if anything's ever been left on to drain the battery during that span.
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
Ronin
Nov 17, 2001 09:46 PM
