Help with audio system!
Old Oct 10, 2009
king.0c's Avatar
king.0c is an unknown quantity at this point
Hello everybody,
I'm looking to put a system in my 2001 Civic EX. I would like to know the size speakers i should be buying and recommendations for the speakers. I dont want a crazy sound system that will shake my car and sound like a ricer. I want a nice clear sound system. Suggestions plz
Old Oct 10, 2009
sl33pyriceboi's Avatar
Re: Help with audio system!
the search button is ur friend. please use it. there are plenty of info about this.
as for a short answer:
coupe and sedan use diff speaker sizes.
coupe: front- 6.5 rear-6x9
sedan: front-6.5 rear-6.5
(off the top of my head, correct my if im wrong)
just remember when u get speakers, make sure the dept of the speaker isnt too much because u might not make clearence.
also, make sure u match ur speaker with ur amp so it is not under powered or over powered.
so make sure ur amp is at least/around 75% of ur speaker's capability.
for example:
amp supports up to 75W rms, ur speaker should support 75+ watts of RMS (like 100rms is ideal)
infinity reference series is a good mid range. more output than stock speakers will ever be able to produce. i run infinity KAPPAs which is there higher end. cant go wrong.
Old Oct 10, 2009
yeah reference infinity on an amp sounds great for low budget.
Old Oct 11, 2009
vsTerminus's Avatar
vsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond repute
If you have the budget, I can't stress enough that you will never achieve a "full" sound in your car without a sub.
It doesn't take much (A pair of 8" or a single 10" is often more than enough), but I don't care what kind of door speakers you buy, they cannot produce those low 20-100Hz frequencies. Ever.
It certainly doesn't need to be vibrating the building across the street, but a little boost at the low end will never hurt.
Old Oct 11, 2009
^vsterminus is correct.
mjdiaz89
Jun 21, 2016 09:26 PM
redcloud
25
Aug 12, 2015 01:23 PM
sch2cm
Jul 21, 2015 09:58 PM
