Good ground point for under seat amp installation?
Old Sep 23, 2009
jmontoya21's Avatar
jmontoya21 is an unknown quantity at this point
hi im in the middle of a system upgrade and would like to hear suggestion on a good ground point for a 2 amp install under the front seats,big 3 upgrade included i could also run a ground wire straight from the battery but it may be to big to fit Threw the fire wall factory grommets,any suggestions will be greatly appreciated.
Old Sep 23, 2009
vsTerminus's Avatar
vsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond reputevsTerminus has a reputation beyond repute
Re: Good ground point for under seat amp installation?
My under the set amp is grounded to the seat belt bolt. I figure, it's bolted directly into the frame of the car, it can't be that bad.
Old Sep 23, 2009
2k5reverb's Avatar
2k5reverb will become famous soon enough
If you want the wires to be hidden just ground the amps to one of the four bolts that hold the seat brackets to the car floor. Just make sure you are getting metal to metal contact.
Old Sep 23, 2009
i used the seat belt bolt on the passenger side and all the wires are hidden under the carpet.
Old Sep 26, 2009
02civicRR's Avatar
02civicRR is an unknown quantity at this point
i grounded mine to the bolts to my seat rail.
Old Sep 26, 2009
tinnguyen123's Avatar
tinnguyen123 is an unknown quantity at this point
i use the negative terminal... or any bolt you find in the back..
superstanko
Apr 28, 2015 04:38 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
McD
Apr 22, 2015 05:28 PM
wsking77
Aug 29, 2001 05:34 PM
