HELP!!! So many problems!!
Old Jun 13, 2009
itzmaryy's Avatar
itzmaryy is an unknown quantity at this point
Hey guys,
I drive a 2001 honda civic ex coupe.
So 2 weeks ago all of the sudden (at the same time) a bunch of stuff stopped working in my car. the problems are:
1. My a/c does not work, blowing out hot air
2. My remote / keyless entry does not work (already checked the batteries)
3. My car does not lock unless i manually do it by pushing it down or using the key from the outside.
4. My e-brake light is on constantly
5. My intermittent wiper blades & mist does not work. Although when i use the mist, washer fluid comes out but the blades does not mvoe.
I did some research on the forums and it might be the Multiplex control unit/system controls all of it, but I'm not sure. Someone please help me!!!!
Thanks
Old Jun 14, 2009
04 Honda Civic's Avatar
Re: HELP!!! So many problems!!
Damn I never even heard of a multiplex contol unit. Id start by checking fuses
Old Jun 14, 2009
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
Check under the hood that all your ground wires are connected. Sounds like one came off also check that the ac belt has not come off. Let me know if you need further assistance.
Old Jun 14, 2009
is your brake fluid low? do you hear the compressor and fans turn on when you use the a/c?
Old Jun 14, 2009
CraigW's Avatar
Here is the list for the items controlled by the multiplex unit. There are also individual fuses that protect the multiplex unit. It is possible that one of those has opened up. There are quite a few threads on these units having problems.
File Type: pdf
Old Jun 14, 2009
CraigW's Avatar
Here is the info for the 2 & 4 door under dash boxes... I would check each fuse that list the multiplex unit.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
