Head Unit Flickering
Old Jun 7, 2009
EM2Driver's Avatar
EM2Driver is an unknown quantity at this point
Hey guys, I have a 2002 coupe with an alpine deck. Just the other day when I turn on my parking lights and headlights, my deck display starts flickering. I can't turn on my deck or change any settings except for the volume.
In order for me to change a track, or anything else I have to turn of my headlights, and parking lights. Its been two years since I've had it installed and never had a problem like this.
If anyone has any insight or tips let me know. I will be pulling everything out tomorrow and checking the wiring.
Thanks
Old Jun 7, 2009
thenewdiabolic's Avatar
thenewdiabolic is an unknown quantity at this point
Re: Head Unit Flickering
possibly a ground gone bad? haha im not too sure, things like this im not too great with.
Old Jun 7, 2009
EM2Driver's Avatar
k thanks, I'll keep that in mind for tomorrow. About a month ago I did install an ipod cable..so it could be a possibility that something got loose when i pulled out the deck and now its got looser
Old Jun 7, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Pull out the deck, remove the wiring harness and examine the wires. Make sure that no two wires are touching. Check the orange wires especially carefully.
Old Jun 7, 2009
EM2Driver's Avatar
ok cool. if i remember reading correctly somewhere, the orange wire has something to do with the dash dimmer switch.
Old Jun 7, 2009
BlueEM2's Avatar
Whachya lookin at?
"Most" aftermarket decks don't have the dimmer wire (my alpine does not), but it will be on your harness. Chances are its taped off just make sure the tape on it is not gone and the wire is not touching bare steel.
The other thing is to check your fuses for your lights, dimmer, etc. Even look under your hood, you never know it could just be a fuse blown or something like that. I've heard fuses do some wacky things in the civic.
Good luck!
Old Jun 7, 2009
04 Honda Civic's Avatar
when u give the car gas and keep it steady does it still happen?
01civicboi
Feb 4, 2002 11:20 AM
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
