No sound from 3 out of 4 speakers on 2005 Civic VP
Old May 12, 2009
douglasbarbin's Avatar
douglasbarbin is an unknown quantity at this point
I have a 2005 Civic VP coupe, with factory head unit/speakers (no tweeters in door for this setup). I bought the car used, and as long as I've had it, only the rear deck speaker on the passenger side produces any sound when the CD player/radio is on. I've tried hooking up a 2000 Civic EX factory CD player, with the same results. I haven't tried an aftermarket unit (I'm missing the wiring harnesses for both a Pioneer and Panasonic head unit, so no luck with that for now), but I suspect that if I did, I would get the same results. None of the speakers appear to be blown or have any damage. I've also tried hooking up different speakers to the factory-installed clips that the stock speakers plug into, and the only one that produces any sound is the passenger-side rear deck speaker. So, as far as I can tell, the speaker wiring is probably bad somewhere between the factory head unit harness and the speakers. Either it's cut or grounding out somewhere, I believe. Is there any way to check this, perhaps with a multimeter or similar device? The way I see it, my options are: 1) trace each speaker wire, check for damage, and repair them, 2) check each speaker wire and replace any that need replacing, or 3) just run new speaker wire to the rear deck and doors. Any suggestions? I'd like to be finished with this problem once and for all, but I hate to go through the hassle of messing with all that wire or running new wire. Perhaps I'm overlooking something? Any help would be much appreciated, thanks.
Old May 12, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: No sound from 3 out of 4 speakers on 2005 Civic VP
You would hear sound even if the speakers were damaged, it would just sound like ****. I wouldnt waste time measuring the wires as you would hear something if there was any voltage.
Plug the wires from directly behind the stereo to a speaker and see if it works. If it works that way, run new wires from the head unit to speaker. Who knows what the previous owner did.
Old May 17, 2009
Another option may be to pay someone to either trace the wiring from harness to speakers and find the problem, or just run new wire. I'm thinking this would be labor-intensive, and therefore expensive, though. Any ideas?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
dano2005
Apr 14, 2015 01:58 AM
mohawkboom
Nov 2, 2001 06:00 PM
