LED light strips (interior)
I was thinking about putting little LED light strips on my dash and around my whole head unit area.
I hear that they come in little strips as thin as a wire and you just put them in a crevice.
I was wondering how hard this would be to do, as i know i can use some sort of adhesive to keep them in place but as far as power sources go and what not, what do i need there?
EDIT:
So something like this is what im referring too.
Any suggestions on a certain brand or any tips on installing?
pics
EDIT:
pics
Re: LED light strips (interior)
instead, maybe put the strips UNDER the gauges where the plastic lip is so they shine upwards and glow. having open leds like that look really tacky. www.besthongkong.com sells a bunch of different strip styles. but i recommend not keeping them in plain view for the above mentioned reasons. i put some leds under the cluster and turned out pretty good.
Try oznium.com They have a good selection of led strips. I agree with everyone that you should keep them out of sight and just let the light shine through. As for installing, you can just tap them to any power source (even your cig lighter) but I'd recommend installing a switch too.
yeah or parking light wire works too on the gauge cluster. i believe its the red/blk wire in the blue plug.
i put some in my ac vents and under my dash cuz i thought having them shining on my cluster would drive me nuts. i got my switches where your foglight button (i think is what it is) normally goes, down next to the cig lighter, which i used as my power
i put some in my ac vents and under my dash cuz i thought having them shining on my cluster would drive me nuts. i got my switches where your foglight button (i think is what it is) normally goes, down next to the cig lighter, which i used as my power. cool thing about putting the switches there, if i get tired of them i can take em out and put the cap back. ta da! no uneeded holes in my car
https://www.civicforums.com/forums/h...mageuser=64711
Some of the work I have done with Oznium Products:
RED Led Evo cluster
PICT3418.jpg?t
RED LED 3rd Brakelight - Ford Ranger
(Tail lights are L1224R LED's)
Plate LED lights from Oznium
Reverse Lights Ford Ranger
Grille LEDs w/ Amber LED running lights
Blue LED Cluster & Interior Ford Ranger
LED Dome Light
RED LED Evo Interior
Cluster Build:
Evo exterior LEDs, Plate LEDs
LED Ranger Console
Evo LED Front Interior lighting
You can do the same thing with a Civic or any car.
i also do these mods professionally for all cars PM me if you want work done.
RED Led Evo cluster
PICT3418.jpg?t
LED Dome Light
Cluster Build:
LED Ranger Console
MamaBear2015
May 27, 2015 12:04 PM
werdnahall
May 17, 2015 11:37 AM
eorlando1
May 17, 2015 11:16 AM
