Amp Power Troubleshoot
Old Mar 30, 2009
meiseman's Avatar
meiseman is an unknown quantity at this point
Hey guys. Yall have helped me before and I need some help again. So I just got a new Pioneer GM-D8400M amplifier for my Kicker L7 sub. But I can't my amp any power. Here's what I know:
- The amp works because i tested it on a friend's car.
- My RCAs are hooked up to the right holes in the amp and the HU.
- My remote wire is hooked up to the HU and the amp.
- When I touch the power wire to the ground wire, I get sparks (so I assume this means it is grounded...)
- The power is coming directly from the battery.
Any help would be awesome.
Old Mar 30, 2009
EezurpaiN's Avatar
EezurpaiN is an unknown quantity at this point
Re: Amp Power Troubleshoot
Where do you have the amp grounded to?
Old Mar 30, 2009
sl33pyriceboi's Avatar
did u turn ur subwoofer output on? its in teh controls of ur headunit
recheck the remote wire if its connected properly
check if u blew the fuse or not.
Old Mar 30, 2009
meiseman's Avatar
I grounded it to the screw that holds the backseats down.
(in a '02 Civic Ex 4DR)
The Output is on in my HU
I'm pretty sure the remote wire is in the right place
My fuses are good on the amp and of the power wire.
Thanks...
Old Mar 30, 2009
EezurpaiN's Avatar
Thanks...
Your ground is likely your problem....Never ground to a stock bolt....Stereo install 101! Ground your amp to your trunk pan!
Old Mar 30, 2009
^yea cuz most of the time, there is is paint on the bolt/grounding area.
try to sand down the grounding area then put ur -wire on it
currently, does ur amp power up? or is it unpowered when you put ur key in and turn it the ACCII
Old Mar 30, 2009
meiseman's Avatar
I sanded down the area before i did anything with my ground wire...
- plus, doesn't it mean its grounded when its sparks with the power wire?
and no, the amp doesn't power up, even when the car is fully on...
Old Mar 30, 2009
^there are only
since you were able to create the spark, then its a power issue...
1. defective headunit remote wire (problem could be from the remote wire
2. try to find another ground. (but if ur ground wire made a spark with ur power wire, throw this probability out)
3. defective amp. something could have happened or you could have shorted something out during trading/shipping/installing period.
Old Mar 30, 2009
phuviano's Avatar
Slowest 7thgen in the GTA
did you disconnect the battery before installing this amp? I'm assuming you didn't, because you said you saw a spark. If you didn't disconnect the amp, you could have blown your amp already.
Old Mar 30, 2009
^well, thats why there is a fuse in the amp itself....but yea, it is possible
Old Mar 30, 2009
phuviano's Avatar
Yeah I know there's a fuse in the amp. I'm just saying that he should still disconnect the battery before doing any type of work that deals with electricity.
Old Mar 30, 2009
meiseman's Avatar
Aight, thanks for all the response...
Yep. I disconnected it. The sparks occurred after the wires were disconnected.
And when you say defective remote wire, how can this be fixed?
thanks
Old Mar 30, 2009
are you sure you have the correct remote wire tapped? test this by applying a 12V test signal to the amp from a spare battery. or even the car battery if you have a long enough wire. see if the amp turns on. if not, amp is dead. if so, amp is fine and remote wire is not hooked to the right wire on the harness.
Old Mar 31, 2009
meiseman's Avatar
So I replaced the remote wire today and all is well. Thanks for all the help guys.
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
cgavin1
Jul 7, 2015 07:10 AM
OPGForce
Feb 7, 2002 09:43 AM
SLeePeR012
Jan 7, 2002 12:24 AM
