alarm help 03 civic lx
Old Mar 24, 2009
skooter05's Avatar
skooter05 is an unknown quantity at this point
Exclamation alarm help 03 civic lx
i just got a scytek 4000rs-2w-1 alarm system and i cant get the door locks to work. what type of door lock system is on the car? its a 2003 civic lx coupe. and if anyone can tell me the wires to hook up that would be great.
Old Mar 24, 2009
CraigW's Avatar
Re: alarm help 03 civic lx
negative trigger system
WHITE/BLUE = Lock
WHITE/GREEN = Unlock
Old Mar 24, 2009
skooter05's Avatar
where are the wires at? i found a large grey harness driver door side under dash and if i unplug it the locks quit working, but when i check those colored wires they dont have any power on them and if i manually ground them nothing happens. i may not be understanding it properly but i think im testing it right i just dont think i have the right harness. thanks for your help.
Old Mar 24, 2009
CraigW's Avatar
I double checked the wire color codes and they are correct. I don't know of any 2 sets using the same color (but never say never)
I posted a similar question a while back as I would like to add a lock/unlock switch on the passenger side area. (I can't locate the thread)
Someone mentioned the security connector plug would have those wires. You may try to access the wiring going to the drivers door, for certain they are found there. The manual shows it available at the under dash box fuse box(multiplex) that would be a mass of wiring IMO.
If you find a good location to access them let me know, I still want to add that passenger side switch !!
Old Mar 24, 2009
skooter05's Avatar
once i find the wire should i measure 12v on it? and can i just ground it to make it lock or unlock?
Old Mar 24, 2009
CraigW's Avatar
The lock/unlock switch just provides a ground path for one or the other of those wires.
Make sure of the wire color and then as a test very quickly and briefly provide a ground and see if your locks respond.
Linda0818
Apr 23, 2015 11:30 AM
loquito
Nov 12, 2001 07:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
ChiFroBoy
Oct 24, 2001 01:32 AM
