speakers and amp
Old Feb 25, 2009
316's Avatar
316
316 is an unknown quantity at this point
speakers and amp
Hi
Just need advice on installing an amplifier to my Honda civic si 2003 in-car speakers.
I have four JL Audio speaker, 75 rms i think (2 front, 2 back) and one amplifier JL 300/4 amp (four channel).
Head Unit -> amplifier - > speakers
Should I use the standard speaker (comes with the car) wire to connect to the amplifier or should I use more thicker/power speaker wire?
Does it make a different if I use standard speaker wire or off-shelf speaker wire?
Where is the standard speaker wire located in the car? At what point is it best to grab the speaker wire?
Where should I place the amplifier? In the back boot?
Thanks in advance, any advice would help.
Old Feb 25, 2009
lordhelmet's Avatar
Re: speakers and amp
I'd change the speaker wire up. That way you can run it to the speakers from where ever you put the amp. It will make a difference using thicker gauged speaker wire or the stock weeny wire. Trace the speaker wire from the speaker. Amplifier location depends on how big the amp is and personal preference of where you want it. Put it under one of the front seats or in the boot. Just make sure to run power wire as far away from any speaker or signal cable running from the head unit to the amp.
Old Feb 26, 2009
316's Avatar
316
Thanks for your advice...
Old Feb 26, 2009
lordhelmet's Avatar
There should be a DIY in the DIY section about this kind of stuff.
Old Feb 26, 2009
KTciv_03's Avatar
KTciv_03 can only hope to improve
you should be good running "speed wire" its a strand of purple, green, white, grey all pos, neg in one bundle bout the size of 4 ga wire. run that by your rca's and tap into the stock wiring behind the headunit. thats the easiest and most efficient way.
Old Mar 8, 2009
Pedrotax's Avatar
Pedrotax is an unknown quantity at this point
I'd change the speakers' wires... I'm telling you by personnal experience.. You can put the amp in the boot if you think its powerful enough...
Good luck with it!
Old Mar 8, 2009
Pedrotax's Avatar
Good luck with it!
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
