02 coupe have Tweeter Plug?
Old Jan 2, 2009
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
So Yeah I got some OEM Tweeters with the mirror covers and LOVE them. Does anyone know if there is a plug to plug the tweeter in in my door? I have an LX and these were on an EX. Let me know!
Old Jan 2, 2009
icedcoco's Avatar
icedcoco is just really niceicedcoco is just really niceicedcoco is just really niceicedcoco is just really nice
Re: 02 coupe have Tweeter Plug?
i don't believe the LX's have the plug. there might be a diy on here somewhere though.
Old Jan 2, 2009
DDragon7's Avatar
I know some LX comes with them, so Im not sure if all of them have plugs or not.
Old Jan 3, 2009
Maple50175's Avatar
I See, I'll prob take my panel off tommrow and see, otherwise I'll just have to cut and splice
Old Jan 3, 2009
i thought only the ex coupe comes factory with tweeters. be careful how you just "cut and splice" you cant just tap them to the front speakers it will mess up the ohm load and possibly blow your stereo. the only way to really add tweeters (without buying aftermarket components that come with a crossover) is if you run the other speakers off an amp and then run the tweeters off the deck power. and also i dont know if the factory tweeters come with any type of bass blocker or small crossover otherwise you will blow them up pretty quick.
Old Jan 4, 2009
Maple50175's Avatar
They do, and yes you can do this, as I was reading the HONDA manual at my work (honda) and that plug goes into the speakers wiring. Its all connected.. I will see again.
Old Jan 4, 2009
99WhiteJDM's Avatar
99WhiteJDM will become famous soon enough99WhiteJDM will become famous soon enough
On my car the front door speakers have two sets of wires because of the tweeters (from the factory). It should be fine to run them on the factory stereo but, if you are using an aftermarket radio, I would suggest using bass blockers. I'm sure if you went to Honda or a junk yard you could buy the OEM plugs for your tweeter/front speaker set up like the EX's but I think it would be easier to just run wire behind the panels and splice them under the dash or behind the deck with the wires for the front speakers. In my car all four wires are connected to one plug that connects to the front speakers in the doors.
Jeffdp
Aug 5, 2015 11:38 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
Allecr3
May 22, 2015 01:24 PM
ademarco6
Nov 16, 2001 10:19 PM
ademarco6
Nov 12, 2001 06:52 PM
