i installed a DEI 529t... couple of q's
Old Nov 16, 2008
sp4rt4n's Avatar
sp4rt4n is an unknown quantity at this point
hey people...
i installed a dei 529t, on my sun roof in my car.. i drive a 2005 honda civic ex. the instructions say that if you have a venting sunroof (which i do) you will need a spdt relay and a dei 452t pulse generator.
my questions you ya'll.
has any one did this to there car?
how did you wire to the factory limit switch?
any input will be much apreciated..
i am a car audio installer, and me and another installer couldnt figure it out.
Old Nov 16, 2008
Re: i installed a DEI 529t... couple of q's
well the pulse generator is so that the roof vents completely and not just a tiny bit. the relay i think is because of the way the switch is wired. i have no idea how to install those things tho.
Old Nov 16, 2008
sp4rt4n's Avatar
bump
Old Nov 18, 2008
sp4rt4n's Avatar
ok i figured it out.. you need a 528t or a tr7 pulse timer to act as a limit switch. if you all would like i could do a write up.. just let me know.
Old Nov 19, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Yeah, I'd love to see it!!!!
Old Jan 1, 2009
sp4rt4n's Avatar
I DID IT!!!!
i used a DEI 452t pulse generator and tapped into the factory limit switch so now when i lock the car the sunroof closes and doesnt vents...
Old Jan 1, 2009
How's the wiring on that now?
Old Jan 6, 2009
tommy81's Avatar
tommy81 is an unknown quantity at this point
hey whats up hope that install went well, um i had a question i have an 04 civic lx coupe and installing a 791xv i got the bypass and ign wires straight but i was wondering about the horn the sheet says its orange- but theres two of them in the steering column also wondering about the keyless entry can i just hook up the lock n unlock or do i need diodes or anything thanks man
Old Jan 6, 2009
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
yeah u need to use a few diodes, i have the same system on my car. with that system though you can add on more with it that makes it nice to have.
to the op yeah those mod are sick i have it on my windoes and now i am going to do my sunroof.
Old Jan 6, 2009
tommy81's Avatar
so is the diode just to make my signal from the brain go out but not come back? so one on lock and the other on unlock? its funny ive been an electrician for 4 yrs but electronics is a bit different
Old Jan 7, 2009
i think i used the diode for the doom light because it was back feeding
Old Jan 8, 2009
No need for diode on lock wires. Test horn wire with a multimeter. If you don't have a meter get out of the car!
Old Jan 12, 2009
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
is the DEI 529T wired the same way as the 530T?
i bought a couple 530T's awhile back but have yet to install them
i wanted to control the front windows and the moonroof.
would be great if you can post up a diy...thanks
Old Jan 15, 2009
sp4rt4n's Avatar
here is the wire diagram
enjoy every one..
Old Jan 15, 2009
sp4rt4n's Avatar
the 529t is 1 window in two directions or 2 windows in one direction
the 530t is 2 windows in two directions
thanks secret weapon...lol i will post this on watercooler also..
Old Jan 15, 2009
sp4rt4n's Avatar
no diodes needed..
Old Jul 9, 2009
doobiest's Avatar
doobiest is an unknown quantity at this point
Hey man could you help me out. I just bought one of these for the sunroof and I can't figure it out.
What I'm trying to do is have the open/close sunroof button be automatic so I don't have to hold them down. I'm not trying to hook it up to an alarm or anything like that, so what I'm looking for might be different than what you did.
Anyway I have it hooked up how I think it's supposed to be but when I hit the buttons it's not automatic, I still have to push and hold. Essentially the same as the buttons originally worked.
Do you know whats up? Can you tell me what the colours were of the from the car? There's 2 red 2 green a blue and a black I think and I'm not sure what they are all for, I just see a 12v signal on 1 green and 1 red I believe.
Thanks.
Old Jul 29, 2009
sp4rt4n's Avatar
well you dont use anything at the switch every thing you need it under the headliner in the back. i am on honda-street.com and 7thgenhona.com more than this site.. hit me up there i check this site one in a blue moon
Old Jul 29, 2009
mdawg's Avatar
mdawg is on a distinguished road
Thanks.
Thats the same thing I want to do for mine, just have it automatic like the newer civics. Let me know if you figure it out.
Old Oct 28, 2011
soccer0915's Avatar
soccer0915 is an unknown quantity at this point
I was wondering do you still have the wire diagram you can repost or pm me? All I see is a red X.
Thank you so much! This will be of great help to me and I'm sure many others! Chris
Old Nov 2, 2011
soccer0915's Avatar
?, Bump. Thanks!
Old Jul 19, 2012
doobiest's Avatar
I bought the parts and completely abandoned this project but I would like to get back to this now. I still can't find any better info online. The wiring diagram would have been helpful.
Old Jul 19, 2012
GolNat's Avatar
Prelude Owner
What wiring diagram are you looking for? The one for the windows and sun roof?
RIPSAW
Jun 9, 2015 08:33 PM
masongap
May 26, 2015 07:55 PM
Schneiderman
May 24, 2015 01:14 PM
CapYoda
Nov 29, 2001 07:37 PM
