Stereo install gone wrong
Old Oct 18, 2008
Badwick's Avatar
Badwick is an unknown quantity at this point
Yesterday I installed a Pioneer DEH-2000mp receiver in my car the hard way, by splicing wires instead of using a wiring harness. Cause I'm dumb. After I got it all done, the front speakers worked, but not the rear. I told a friend and he told me to just go out a get a wiring harness. Awesome. I did. I installed that and it didn't work. I said forget and reinstalled it the way I had it. Now the stereo doesn't work, the locks don't work and all my gauges have a seizure for about 5-10 seconds every time I turn me car on. What the hell did I do?
Old Oct 18, 2008
hwt101's Avatar
hwt101 is an unknown quantity at this point
Re: Stereo install gone wrong
you could have grounded out something, check your fuses. just my 2 pennies. good luck. Also you should be able to splice a radio in with out issues as long as you got every wire matched with its correct wire it just takes longer that way.
Old Oct 18, 2008
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Check the fusebox under the hood look for fuse #9. It is a 10 amp fuse. When I blew it last weekend my door locks would unlock but not lock. My gauge cluster acted flaky, and my radio wouldn't power on.
Old Oct 19, 2008
Badwick's Avatar
tbaleno, you're awesome. Fuse #9 was blown. I replaced it and now everything works. Thanks a ton.
Old Oct 19, 2008
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Backup fuse FTW.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Youngciviboy
Jun 10, 2015 03:49 AM
4 banger
Jun 5, 2015 01:44 AM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
