fuse for 5w bulb?
Old Feb 28, 2008
fuse for 5w bulb?
i just realized i never fused my hood light, would a 5 amp be fine? and can i use a mini one?
Old Feb 28, 2008
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Re: fuse for 5w bulb?
watts= volts X amps
so if you know your headlight's wattage. There you go...
Old Feb 28, 2008
ah okay looks like 1 amp is fine.
Old Feb 28, 2008
Lord ET's Avatar
I'd probably go a little higher just for safe measure, but w.e.
Old Feb 29, 2008
electric130's Avatar
what size wire did you use? that's the main thing.
Old Feb 29, 2008
Lord ET's Avatar
yeah i guess watts = VxA only if the wire is big enough not to have substantial resistance
Old Feb 29, 2008
not even a matter of resistance. you fuse a system so that the current doesn't exceed the rated capacity of the wire. that determines the max fuse. you can always go smaller to protect the components, but the max is determined by the wires used.
Old Feb 29, 2008
oh hmm i think 14 or 16 gauge? it was way bigger than it needed to be.
Old Feb 29, 2008
Lord ET's Avatar
yeah. usually 20awg is big enough for like ... 3 or 4 amps on 12V
shaejb15
Sep 3, 2015 01:35 PM
shaejb15
Lighting
Sep 1, 2015 12:37 AM
jonwalden68
Aug 27, 2015 12:07 PM
mac25
Aug 21, 2015 11:14 PM
OsOBooSTeD
Mar 5, 2003 02:57 AM
