defroster interfieirs with antienna
Old Jan 6, 2008
sentbacktothesu's Avatar
sentbacktothesu is an unknown quantity at this point
so lately ive noticed that if i listen to the radio its fine, until i put on y rear defroster. it pretty much cuts out all radio signal and is just static. it only doesnt really bother one (just so happen the closest to where i live). but all others is cuts out.
something isnt right... anyone have any suggestions?
Old Jan 6, 2008
Re: defroster interfieirs with antienna
check to see if there are any breaks in the lines. the antenna is the middle one going vertical.
Old Jan 6, 2008
jlilly08's Avatar
jlilly08 is an unknown quantity at this point
Mine does the exact same thing. I just put in a cd until my window is defrosted, then i listen to the radio
Old Jan 6, 2008
TRIZ's Avatar
Pop of the rear passanger piller and make sure thats all good.
Old Jan 6, 2008
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Mine has done the same thing for the entire life of my car.
Old Jan 7, 2008
triz, when i take that panel off. what should i be looking for. i understand whats there but what would be wrong that i could diagnose?
Old Jan 7, 2008
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
Mine does that as well...it only goes bad when the radio signal is not strong enough....but with crap OEM radio it does that most of the time..
Old Jan 7, 2008
TRIZ's Avatar
Oh its been a while since I've looked at that panel. there should be a wire or two visible. Make sure they are connected, not frayed or loose or anything. Then trace the lines on the rear window to see if any of them are cracked or apart. Its like christmas lights- pull one out and the whole thing is fvcked.
Old Jan 9, 2008
i took it appart today and looked into it. i dont see any cracks in the lines in the window and that box and wires seem fine.
Old Jan 9, 2008
TRIZ's Avatar
Does the defroster button light up when you push it?
Old Jan 9, 2008
ncirom2003's Avatar
i see this alot on bmw's (i also work on bmw's only lol) rear window needs replacement! like gearbox said theres gotta be some breaks in the lines
Old Jan 9, 2008
yeah everything works as it should. the light, the defroster, it just seems to mess up the radio signal. the only thing that could possibly lead to this happening is me taking off my tint. but im not sure i don't remember if it did it right after i took it off or after i did. if i need a new window i think ill make some enemies and park my car in a bad part of town. lol
Old Jan 9, 2008
greeen01civic4d's Avatar
u dont need a new window, u need an electrical tester, all u have to do is start at the power side, follow each line across the window, the light on the tester will glow brightly at the power side, and the farther u get from the power source, the dimmer it will get, if it suddenly cuts out, u have damage to that line, and need to repair it, its available aftermarket at napa and such places, so do not just replace the whole rear window, test it first
Munzy
21
Oct 7, 2015 07:48 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
BigG422
Sep 9, 2015 10:59 PM
