Help!!!!!
Old Dec 15, 2007
miami_em2's Avatar
miami_em2 will become famous soon enough
Help!!!!!
I have a huge problem My passenger window will not work. Won't go down nor up. I thought it was the motor or the switch, so I went and bought both. It wasn't that. Then someone said something that it migt be the driver's main switch, so i bought that also. It wasn't that. I think it might be a relay or something. I really need help on this one. Does anyone have a schematic sheet on the wiring for the windows. So I can fix this problem asap. I would really appreciate it. Thanks in advance
Old Dec 15, 2007
pnoyster2k1cvic's Avatar
Balut Eating Champ
Re: Help!!!!!
have you checked the fuse?
Old Dec 15, 2007
miami_em2's Avatar
Re: Help!!!!!
yup....every single one in the car
Old Dec 15, 2007
miami_em2's Avatar
Re: Help!!!!!
afternoon bump
Old Dec 15, 2007
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Re: Help!!!!!
try to follow the wires...maybe one got piched somehow...?
Old Dec 15, 2007
CraigW's Avatar
Re: Help!!!!!
You will need to check for voltage present at the motor and work backwards from there.
7th gen Civic ?? If so, PM with an E-Mail address and I can send you some info.
