one DVC or two SVC subs??
Old Mar 31, 2002
Foom's Avatar
Foom is an unknown quantity at this point
Hey guys and ladies...I have one quick question...is it better to have a single DVC sub or two single voice coil subs in your car?? Which setup would sound better and be louder? I'm more concerned about sounding better, but I'd also prefer the subs to play louder rather than softer. I'm leaning towards a single DVC so there would be more trunk space left, but let me know what you think.
Old Mar 31, 2002
mohawkboom's Avatar
well depend son the actual ohm loads of the subs... but the vpice coil configuration has vey little to do with how loud or how well a sub will sound...
Give us more info on what kind of sound you want..
What kind of music you listen to
And how much your willing to spend on a sub and an amp for it and we'll get back to you
Cheers
Mohawk
Old Mar 31, 2002
Foom's Avatar
well, I don't know how much I'm willing to spend on the subs and amp yet, but I definitely prefer better sound for a little bit more money than crappy sound. I don't know...I guess around $300 for an amp and another $200-300 for sub(s).
I was wondering about DVC and SVC b/c I want a 2 ohm load of either setting up one 4-ohm per coil DVC sub in parallel, or two 4-ohm SVC subs in parallel.
The sound quality goes down as the ohm load goes down, right?? Is it really that noticeable between 4 and 2 ohms??
Old Mar 31, 2002
mohawkboom's Avatar
for subs the sound quality isn't really noticable..getting a 2ohm load could be too low an ohm load for your amp.. if you want a 2ohm load you'll need a 2ohm mono stable class D amp..
For that price range you have a few options.. mainly to run a single 12" sub.. a 12" Kicker L7 would be a pretty choice.. as would an Adire audio Shiva... an Audiomobile EVO..all subs that will play loud..have good low end and all designed for sound quality first...all under $300..
Cheers
Mohawk
Old Mar 31, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
You can get an MTX 6500D Amp for $309 at onlinecarstereo.com. It says 500x1 at 2 ohm, but i think that is just the minimum that the company will allow to sell the amp. I recommend this amp. Good luck!
Old Apr 1, 2002
mohawkboom's Avatar
<< You can get an MTX 6500D Amp for $309 at onlinecarstereo.com. It says 500x1 at 2 ohm, but i think that is just the minimum that the company will allow to sell the amp. I recommend this amp. Good luck! >>
that's 500Wrmsx1 into 12.5 volts.. at 14.4 it's 750Wrms.. but most of them put out 850-950Wrms
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
sf3r8z
Sep 23, 2015 03:26 PM
redcloud
Sep 7, 2015 01:45 PM
