DIY Auto Headlight Turnoff?
Old Oct 30, 2007
xd2005's Avatar
xd2005 is an unknown quantity at this point
I wonder if anyone's done this, especially with easily accessible relay for those with PnP HIDs
The 7th Gens have lights that stay on if you turn the engine off.
Wiring a relay that's controlled by ACC wire to the power wire from the HID relay would solve that problem wouldn't it? Or is there something I'm missing?
Also, I've got a PnP kit that ignites everytime I flash my high beams. Anyone with similar issues?
Old Oct 30, 2007
sl33pyriceboi's Avatar
Re: DIY Auto Headlight Turnoff?
u have a 04-05 civic dont u?
Old Oct 30, 2007
xd2005's Avatar
yea, the 01-03s auto turn off i suppose?
Old Oct 30, 2007
no. the 01-03 is a H4 based bulb which only the highbeam or lowbeam turns on at a time... its an either or situation...
the 04-05 are 9006/9005 based.....lowbeam turns on....then highbeam turns on w/ lowbeam stayign on...
ofcourse this can be bypassed in the 01-03
Old Oct 30, 2007
and im sure this autoshut off can be done......with a lil rewiring and some relays and circuit boards
Old Oct 30, 2007
you can use the acc wire, but then they will also turn on automatically, and flash off again when you turn the engine over, which is very bad for the ballast. and there is no way to disable flash to pass mechanism without opening up the switch and reworking the circuit.
Old Oct 30, 2007
xd2005's Avatar
right you are. I guess it's only useful if you really want to guard against leaving your lights on, which the dealer did once
Old Oct 31, 2007
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
i love having highs and lows on at the same time looks so good when you have a 4300K HID kit for highs and then a 5500K Kit for lows lol.. plus if one bulb on low goes out, you have 3 others
Old Oct 31, 2007
i guess the easy way is get a delay timer, set it for 10 secs or something, that way when you start the engine, they will remain on instead of flashing off. and hook the harness to the acc wire and route everything through the timer. its around $20 for the timer, i have one new that i never got a chance to use for anything.
Old Oct 31, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
i say get a light sensor (legos) find the setting u want and itll automatically turn on and off depending on outside light
Old Oct 31, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
The ignition wire (black/yellow) should hold power in crank.
Old Oct 31, 2007
but, the ballast will shut down when it gets less than 12v. cranking will drop the power level quite a bit, prolly down to 6v even. i have led markers i designed and they almost completely turn off during starts. theyre wired for 12v so i can guess they must be getting only 6-9v max.
Old Nov 1, 2007
electric130's Avatar
on my 02, there's a really loud and annoying buzzer that sounds if you turn the car off and the lights are on. pretty hard to forget to turn them off with that thing making all that noise.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mark1974
Jul 28, 2015 08:18 PM
beeemerdude
Jul 23, 2015 03:53 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
Jul 12, 2015 11:54 AM
