tachometer stuck at 2000 rpm
Old Oct 16, 2007
ccarbo's Avatar
ccarbo is an unknown quantity at this point
Anyone know how or why the tachometer is stuck at 2000 rpm?? It was working and then one day I noticed it not working. I pulled the fuse but nothing helped? Any clues or suggestions?? Thanks.
Old Oct 17, 2007
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Re: tachometer stuck at 2000 rpm
Do you have the aftermarket glow gauges or is it just stock?
You can probably just open up the cluster and gently put it back at the stop point.
Old Oct 17, 2007
ccarbo's Avatar
it is stock.... how hard is it to get the cluster off?
Old Oct 17, 2007
manahoonie's Avatar
there's a DIY in the DIY section...
Old Nov 14, 2007
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
something is probably wrong with the cluster...
all the gauge needles are controlled by small little stepper motors
Old Nov 19, 2007
awang's Avatar
awang is an unknown quantity at this point
i'd go to honda for this one. i've had this problem with mine before, only it was around 3400 ish. i don't know what they did, but they fixed it and didn't charge me
cukaracha
30
Jul 26, 2015 12:01 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
Jul 12, 2015 11:54 AM
1khilari
Jul 9, 2015 08:12 PM
Ninetyatecivic
May 9, 2015 07:48 PM
