How should I run this?
Rep Power: 0 How should I run this?
Ok, I just bought a Phoenix Gold xs4300 amp from a friend because it was a great deal, and I though it would power my new JL Audio vr600-cs component set well. The amp is rated at 12 x 4 into 4 ohms at 12.5 VDC, 35 x 4 into 4 ohms at 14.4VDC, and 150 x 2 into 4 ohms at 14.4 VDC. Now the componets recommended power range is 15-100 watts. 150 watts is going to be too much, isnt it? I dont believe the crossovers included with the components will allow me to bi-amp the set. Any suggestions? Oh, and I plan on running no rear fill, so this amp is only to power this speaker set.
1 Post
Rep Power: 0 if the crossovers allow for Bi-Amping that's definately the way to go.. Otherwise.. bridge it to 150Wrms and just keep keep the gains low..your ears will blow before the speakers do.
Cheers
Mohawk
Cheers
Mohawk
lilrob1213
37
06-29-2015 06:45 PM
hokiedad4
05-03-2015 10:06 PM
dragonsblood
04-27-2015 12:28 PM
