02 OEM Stero into '00 Civic
Old Jul 25, 2007
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Is it possible to put the 2002 OEM stereo into the 2000 civic without any modifications? (no wiring harness & mounting bracket)
OEM -> OEM
Old Jul 26, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: 02 OEM Stero into '00 Civic
Honda 98-Up into Radio Plug 71-1721 $11.50
Honda 98-Up into car 70-1721 $11.50
Well, according to installer.com the harnesses are the same part number for both the radio and the car. As well as the model year. Although I think you'll have more of a problem making it fit physically into the dash rather then having a wiring problem. But of course I cannot actually confirm this because i've never tried to do it. I have a feeling that if you wanted to actually do this, you're probably going to need to trim the 2000 mounting bracket.
Do you have these all for free or something? If you're going to spend money on doing this, I think you should just get an aftermarket unit. It's probably cheaper, and better quality. Also allows you to expand to a subwoofer and amplifer system.
Old Jul 26, 2007
Envy's Avatar
Diamond Member
well its just that i got an alpine, and my grandmother has an 2000 civic, with no CD. She wants my old one, a CD player, and it looks (eyeballing it) like it would fit right in (they have the same trim shape)
Old Jul 27, 2007
Eyger's Avatar
Well, I know for a fact that the aftermarket mounting bracket is different between the 6th and 7th gen, I used to work in the mobile department at best buy a while back, and at that time, didn't have a mounting bracket for the 7th gen yet, so the installer had to cut down the 6th gen bracket to make it fit. But I guess that could have changed since then. Well, I say give it a shot and see what happens. Worse that could happen, it doesn't fit. Oh well. And if it doesn't fit, then you could always shell out like 40 bucks for a cheap *** cd player and install that in your g-mas car. I don't think she'll be looking for thigh slappin bass or anything unless she's freaky like that. And maybe if you do something nice like that, she'll put you in the will.
Old Jul 27, 2007
Envy's Avatar
Diamond Member
anyway thanks for the info. will try it out.
bsmiley
Apr 27, 2015 01:27 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
slikor
Nov 1, 2001 04:13 PM
