Newbie Install Question
Hi guys if there's a specific forum/thread for this kind of question please direct me there. I'm gonna attempt a HU swap (which I figure should be simple)
When instructions tell you to "tap into a wire" e.g. 12V or ACC, what kind of connection do you do?
Example: I'm considering replacing my Alpine CDA-9856 (installed by BB) with IVA-D105 in my 05 EX AT Sedan
When I find the brake and e-brake wires, how do I connect the deck wiring to them?
I also want to add the KCE-300BT module, which has a separate power harness? Again, how is this meant to be connected? To the factory wires, HU wiring harness?
Please also let me know if this is too much for my first install. I'm pretty good at following directions and understand electrical principles, but am wary of making any major modifications.
Thanks!
Thanks!
Re: Newbie Install Question
Is it a flip out DVD unit? And it's asking you to hook the wiring to the parking brake wire?
You have 2 options:
a) hook it to the parking brake wire like suggested and your install will be legal. You will not be able to watch video while the car is in motion.
--EDIT--
b) please do not discuss, suggest, or endorse illegal activity.
thanks,
Electric130
I DO NOT suggest option b as that would be illegal and not condoned on this site. However it is possible. For option a, get some of these wire taps. Wire a goes into one side, wire b goes into the other side and you flip the lid closed. This pushes the metal piece into both wires thus connecting them.
You have 2 options:
--EDIT--
thanks,
Electric130
thanks for the info. Now about the KCE-300BT unit and possibly other add-ons that require connection to 12V power, where and how do i make these connections?
I was thinking, it is okay to crimp (or otherwise attach) ground and power wires from these addons (separate from HU) onto the corresponding wires on the HU harness?
https://www.civicforums.com/forums/search.php
So this 300BT is kind of a bitch. It's more the settings on the unit (IVA-D105) that are tough than anything. Make sure to read and follow the 300BT manual closely when you have to do the settings after the install.
You have to hook up the pink/black on the back of the in-dash to the pink/black Audio Interrupt Out on the 300BT.
Accy (red), 12V (yellow), Ground (black) on the 300BT could in theory go either to the radio harness (colors will match up) or the ignition harness (colors won't match up and they will be plenty fine current capability for the bluetooth) and then a metal ground for the black.
Just let me know what about that makes no sense so I can try to be more clear.
Tim1959
May 10, 2015 03:56 PM
GabberHead
Nov 20, 2001 07:32 PM
Ronin
Nov 17, 2001 09:46 PM
