Question about bridging an amp
Old Mar 26, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
First of all, "bridging" is the term used for hooking up one sub to an amp right? I have an amp and I am not sure the right way to bridge it to a single subwoofer. I think I have it done right but I am not sure. Thanks all!
Old Mar 26, 2002
mohawkboom's Avatar
Bridging is the term used for turning 2 of an amps channels into one output. By wiring the positve of the right chanel with the negative of the left channel... Here's a crappy drawing
()____()
()=speaker wires.. basically leaving the 2 -/+ channels in the middle not wired to anything
Cheers
Mohawk
Old Mar 26, 2002
bobbyd's Avatar
Thanks again Mohawk! One more thing, do I just plug my rear RCA's into the rear outlets on the amp liek normal?
Aslo, I decided to do the custom box thing and I am going Friday to give the guy a deposit to build it for a single 10" JL. Thanks!
Old Mar 26, 2002
mohawkboom's Avatar
Be absolutely sure he builds it to JL's specs...
Also to bridge em. do you have a 4 channel amp, or a 2 channel amp?..
Cheers
Mohawk
Old Mar 26, 2002
bobbyd's Avatar
Yeah, he said that he had JL specs for every woofer even the old w1 [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] My amp is 4 channel but it says it can be used as 2 channel i think. Thanks again! I am learning a lot from you
Old Mar 26, 2002
mohawkboom's Avatar
the amp can be used as a 2 channel so you'd bridge 2 channels for the sub. and use the other 2 channels for your front speakers?
redcloud
25
Aug 12, 2015 01:23 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
