head lgiht wiring schem. for 2001?
Old Jun 10, 2007
paradoxblue's Avatar
trying to find a schematic or even wire layout for the head lights on a 2001 coupe.
basicly. what wires there are, what controls high and what controls low.
colors etc.
Trying to build a harness for someone
thanks!!!
Old Jun 10, 2007
Re: head lgiht wiring schem. for 2001?
just look at the plug wire colors. the diagram is not really correct otherwise, its just for reference that i threw together for the wire functions. the 12v wire is always hot when hi and lo beam are on, thats what you tap to the upgrade harness trigger. when you use lo beam, the 12v wire is hot, lo beam wire is ground, and hi beam wire is hot. when hi beam is used, 12v wire is hot, lo beam wire is hot, and hi beam wire is ground. this is for h4 headlight only in usa.
but if you use a new relay harness, all you need to do is tap the 12v wire for trigger, then the harness sends power from batt to ballast (the ballast gets grounded to chassis). im assuming this is for hid?
Old Jun 11, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
great post man! +rep..
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
supercivic01
South
Nov 30, 2001 11:27 AM
