Stock deck wiring Q's
Hi, The sony deck that i installed on my 05 civic broke last week and i'm going to put back the original stock deck. However, I dont' know the order or where each colored wire plugs into the back of the deck. Does anyone know a site or how I would go about finding this out? If i knew which pins in the back of the deck was for, I should be fine.
Thanks.
Thanks.
Re: Stock deck wiring Q's
If you did the install of the Sony correctly you used a harness. So you should be able to unplug the harness from the stock wire harness and then plug the stock harness into the stock radio.
If you cut the stock harness to hard wire the Sony you should have kept the stock harness for this reason. Then just rewire the stock harness back in. Just match up the wires and crimp them.
If you discarded the stock harness then. Good Luck.
THIS IS FOR THE 05 VIC
+12V DC Battery(Constant) White/red 9 10 Amp Fuse box under hood
Switched Accessory Yellow/red 8 7.5 Amp Fuse/relay box under dash
Ground Black
Illumination Red/black
Left Front + Green/black
Left Front - Light green
Right Front + Green/yellow
Right Front - Gray/red
Left Rear + Blue/white
Left Rear - Blue/black
Right Rear + Pink
Right Rear - Blue/yellow
AT SPEAKERS
Wire Function Color Note
Left Front Mid + Green/black Green/yellow for Hybrid and Sedan Left Front Mid - Light green Gray/red for Hybrid and Sedan Left Front Tweeter + Green/black If equipped. Red in the Sedan Left Front Tweeter - Light green If equipped. Blue in the Sedan Right Front Mid + Green/yellow Green/black for Hybrid and Sedan Right Front Mid - Gray/red Light green for Hybrid and Sedan Right Front Tweeter + Green/yellow If equipped. Red in the Sedan Right Front Tweeter - Gray/red If equipped. Blue in the Sedan
Ground Black
Right Rear + Pink
geoffm1234
Exterior DIY
Jun 3, 2015 08:18 PM
jackoncruzpr
May 24, 2015 12:24 AM
