93 D15 O2 sensor wiring (4 wire sensor)...
Old May 23, 2007
UpstateNYA4's Avatar
UpstateNYA4 is an unknown quantity at this point
OK all, I'm a noob here, although not to cars in general. I need to know which wires are which on a 93 Civic LX D15 on the O2 sensor. The car needed a new sensor and I got a new one that needs the OEM connector spliced on. On the new sensor, there is a purple wire (signal to ECU), two brown wires (heater wires), and a tan wire (ground). On the car's existing OEM sensor, the four wires are white, green, and two blacks. I'm assuming from prior cars that white is the signal wire, green is the ground, and the two black wires are the heater wires. Is this correct? Also, does it matter which heater wire connects where when hooking them up?
Thanks in advance for the info - new to Civics in general and trying to get up to speed, not to mention start getting the gas mileage this thing should get.
Old May 27, 2007
electric130's Avatar
Re: 93 D15 O2 sensor wiring (4 wire sensor)...
you can probably get an answer over at www.honda-tech.com that board deals more with other gens of civics. this board mainly has 7th and 8th gen people on it.
PaintYaCity
Oct 26, 2013 12:58 AM
90civicekhb
Feb 10, 2011 12:33 PM
hondishi
Oct 18, 2010 02:38 PM
crosses
Mar 2, 2010 03:55 PM
chris04
Mar 23, 2009 11:56 PM
