vtec/o2 sensor question
Old Mar 23, 2009
chris04's Avatar
chris04 is an unknown quantity at this point
hey guys and gals, im kinda new to honda but im having an issue with my car and for the life of me cant figure it out. first i will tell you what i have.
i have a 96 coupe 5 speed, its got a D15B motor. the computer is the stock 96 5 speed. it apears to have all the stock wiring. the check engine light is on due to the code for the o2 sensor. it only has one in it below the header, cant locate a pigtail for the lower one even though the 96 should have one... when i got the car it was having a cooling issue turned out to be the radiator, got that all fixed. but because im shipping this to germany to be safe we changed everything, water pump, hoses, radiator, thermostat and we changed the head gasket.
now my problem, before all this even with the CEL on and overheating the vtec worked perfectly. upon reassymbly i have no vtec. ive ran through all the tests, the solenoid clicks when power is applied, oil level is perfect, operating temp is fine,i cleaned the screen and the solenoid itself and checked for blockage and free movement of the piston inside of it....i have no clue why after removing the head it wont work. i compaired the gaskets and they were the same, as the parts store showed the same part number for the d15 as the d16 original motor. what else could i be missing? could it finaly just need to have the o2 sensor addressed? also when i got the car it had no cats and no simulators, but like i said the vtec worked, i have sence added a cat and cleaned the upper o2 sensor but the CEL is still on and i have no clue, i ran out of time before having to ship the car so im trying to get ideas and maybe parts together before i meet up with my car in 2 weeks so i can fix it. any help? thanks in advance!
Old Mar 23, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: vtec/o2 sensor question
The o2 sensor is in no way related or has any connection to the v-tec solenoid. the vtec solenoid runs on a completely different circuit that is in no way tied to the o2 sensor. So your o2 sensor is not causing the problem. I would jumper the EMS (I think thats what it is called it's late) connector and read the engine code to see what cell you are flashing or else get it scanned that will tell you a lot right there.
Old Mar 23, 2009
04 Honda Civic's Avatar
yea definately pull the code..wont be related to the 02 sensor though
beantech
Jun 15, 2015 07:09 PM
juror
Jun 9, 2015 02:15 PM
juror
May 26, 2015 06:35 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
