no sound coming from alarm
Old Apr 24, 2007
vino's Avatar
vino is an unknown quantity at this point
i have a compustar alarm w/ remote start. problem is there is no sound so when it's alarming only the lights flash. i really dont want to take it back to the shop because they're always busy so maybe you guys can help me out on this one. alarm works fine just no sound.
Old Apr 24, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: no sound coming from alarm
Probably in a valet mode. Could be an issue with the siren though. Model #?
Old Apr 24, 2007
vino's Avatar
just checked and its not in valet mode
model #1WAMR-G2
Old Apr 24, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
check the wiring going to and from the alarm. if a ground/power wire got disconnected the alarm wont sound. The same thing happened to me, I had a ground wire fall off. Just double check everything.
Old Apr 24, 2007
Can you check for 12V at the two wires at the siren when it's supposed to be going off?
Old Apr 24, 2007
dalaw's Avatar
Bone Stock!
worst case is that your siren is blown, which was what happened to me.
Old Apr 24, 2007
civic_04's Avatar
civic_04 is an unknown quantity at this point
this has happened to me before, you probably turned the siren off, for my remote you have to hold I and II for 1/2 second, not sure if that will work on yours since it is a different model
Old Apr 24, 2007
i had my siren cable snap cause circuit city installed it with the wires stretching out. so i just reconnected it and worked fine.
Old Apr 25, 2007
electric130's Avatar
got the manual for the alarm?
Old Apr 26, 2007
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Read the manual. Make sure you didn't mute it. If not, then continue your trouble shoot. I believe the siren is a positive trigger. I would test for voltage there when you know the siren should be going off. Perhaps check for continuity from the siren to the brain box to make sure the wire is still connected. Make sure to unplug that harness first. Check to make sure the ground for the siren isn't corroded. There's multiple possibilities. You have to stat somewhere!
Old Apr 26, 2007
is it raining by any chance? lol. that was my first problem and the ground wasnt very good so every rain the siren wouldnt work, then once it dried everythings fine again
Old Apr 26, 2007
cato1978's Avatar
cato1978 is an unknown quantity at this point
Maybe it's just broke..... j/k... Seriously though, don't get too crazy in the wiring b/c if it's a recent install it probably has a warranty. And if you do take it back, and you have been digging all in the wires, don't tell the shop you messed with it. Make them fix it.
danace99
23
Jun 28, 2015 08:49 AM
MamaBear2015
May 3, 2015 02:17 PM
Linda0818
Apr 23, 2015 11:30 AM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
