gauge lights shorted
Old Apr 2, 2007
wontonamo's Avatar
wontonamo is an unknown quantity at this point
i was installing my HU and when i turned on my lights, the guage cluster wasn't illuminated. i must have shorted something. anyone know how to fix this?
Old Apr 2, 2007
AmbulanceMonkee's Avatar
Re: gauge lights shorted
check all your fuses.
Old Apr 2, 2007
wontonamo's Avatar
they've been checked and everything looks fine. i can't seem to find the root of the problem
Old Apr 2, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
check if wires behind the deck are touching or if you hooked up the organge illumination wire, it wont work and you dont need it.
Old Apr 2, 2007
wontonamo's Avatar
i hooked up the orange wire, is it needed?
Old Apr 2, 2007
illum wire can be used, it just dims the deck light when parking light is turned on. the dimmer wire you dont use, but if you somehow connected it wrong or grounded it out, you fried the dash lights and there is NO fuse for that circuit. so have fun replacing all those lil pieces and cluster. if you checked every fuse and theyre all good, then you burnt out the whole circuit.
Old Apr 2, 2007
wontonamo's Avatar
if what you said is what happened, im going to have to take it to honda to fix. thank you guys for all of your help.
Old Apr 2, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
You may want to check fuse #2 under the hood (it's a 15A).
Old Apr 2, 2007
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
Hey Gearbox. If he were to swap in a new cluster would that fix this problem? I blew mines as well but am interested in just doing a 03-04 swap instead of just replacing with same. Or could it have blown outside of the cluster? What would be the easiest way to fix this problem DIY if possible.
Old Apr 2, 2007
well idk if it burns the wiring too, i am guessing if you replace the dash pieces and they work again, then its just the pieces and replacing the cluster would work too. im sure i have a spare dial piece i can send you with some bulbs.
zaboomafoozarg
May 30, 2015 09:21 AM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
1028CiViC
Bolt-on Engine Performance
Nov 18, 2001 05:02 PM
fordfocussucks
Nov 6, 2001 03:16 PM
