looking for sensors trick for a civic
Old Feb 10, 2007
puertorro's Avatar
puertorro should not be trusted
is there a sensor i could trick for my civic like temp sensor for toyotas or timming sensor of mitsu please post some
Old Feb 10, 2007
TRIZ's Avatar
I got no idea what your talking about, and thats probably the same story with everyone else here, how about you explain your questions a little better?
Old Feb 10, 2007
Alpha 5's Avatar
You can put a resistor in place of your IAT that is a "sensor trick" but those of us here that know better do not recommend "tricking the ECU".
Old Feb 11, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
WHY? would you want to do that?
Old Feb 11, 2007
Alpha 5's Avatar
^^^To answer your question. The reason some people do it is to make the ECU think the air is colder than it is, and colder air is denser air therefor the ECU will tell the injectors to spray more fuel. So they think that they get more HP from doing this. I say it will do nothing in the cold and make it run rich in the summer. A car that runs rich is actually losing HP.
Old Feb 11, 2007
hwt101's Avatar
ah, thanks.
Old Feb 11, 2007
car runs too rich as it is, no need to risk messing up the engine for something that will only cause problems.
Old Feb 12, 2007
puertorro's Avatar
thanks that;s what i wanted to know , but it's true that works for some cars anyways what i did was that i make a alumminum base and take off the wippers engine made the line, fuel presion regulator just in case , fuel filter just in case, the fitting on the air intake, a ford mustang injector and really gave him something.
i ran with a matrix and lancer mivec, they aint got to look for nothng here
is not much but i feel proud of my piece of ****
Old Feb 12, 2007
2k2civic's Avatar
^^^What did he just say?
Old Feb 12, 2007
Kevbotron's Avatar
I like my commute
is that pseudocivic???
Old Feb 12, 2007
So.Ill.EM2's Avatar
Ultra-Platinum Super Bonus Member
So.Ill.EM2 is just really niceSo.Ill.EM2 is just really niceSo.Ill.EM2 is just really niceSo.Ill.EM2 is just really nice
*confusion*
Old Feb 12, 2007
Alpha 5's Avatar
SOmeone has had too much Koolaid!
Old Feb 12, 2007
Rufus's Avatar
I plugged this into my nonsense translator and it ejected the following statement:
"Thanks for the input. I can, however, attest to the success of my theory from my own experimentations where I used a pop can, my old window wipers, a random fuel pressure regulator (in case of...stuff), a fitting laying around, and one clogged injector I found in my couch cushions, and something else I will fail to describe for you now.
I exercised with my buddy Lance while we watched The Matrix. No need to look here though, I may not go a lot but I'm proud of my ****'s."
Old Feb 12, 2007
AmbulanceMonkee's Avatar
wow, you know you're a douche when the mods are ripping on you.
Old Feb 12, 2007
Kevbotron's Avatar
I like my commute
that's great.. I seriously think it's that pseudo guy
Old Feb 12, 2007
Rufus's Avatar
Don't blame me, blame my translator
Old Feb 12, 2007
2k2civic's Avatar
Seems to be....judging by his pseudo English.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
ezone
24
Oct 30, 2017 11:27 AM
bsmiley
Apr 27, 2015 01:27 PM
dragonsblood
Apr 27, 2015 12:28 PM
