Problem with power to my cd player
I recently put a new groundwire kit on my car. The install went fine and everything works, except for my Kenwood KVT-715DVD. It doesn't seem to be getting power.
Does anyone have any ideas about what to do? I checked the fuse in the fusebox for the radio and it looked fine. Is there another fuse that I should be looking at? Is there a fuse in the back of the Head Unit itself?
Thanks for any help.
In that particular head unit. There are a coulpe fuses. There is one on the Yellow wire coming from the deck, and one on the yellow wire coming from the brain. Also, in the under dash fuse box, make sure the cigarrette lighter fuse isnt popped. You can also check to see if your getting power with a multi-meter, on the factory harness, test pin #1 and pin #10.
SSMatey
Apr 13, 2015 06:09 PM
