i got Sirius for Christmas
Old Dec 26, 2006
FALKEN's Avatar
Civicforums Junkie
im not sure where/how i want to mount it...any suggestions?
Old Dec 26, 2006
pon55's Avatar
I got serious christmas eve, and mounted it!
Old Dec 26, 2006
FALKEN's Avatar
Civicforums Junkie
wow, thats was helpful
Old Dec 26, 2006
pon55's Avatar
jessssssssssssssssss lighten up lol
(sorry)
Old Dec 28, 2006
bbrannan's Avatar
bbrannan is an unknown quantity at this point
sirius radio
if it's a plug and play unit (depending on size) mount it to the spot to the left of the cigarette lighter. run the plug in cables behind it using the spare switch cover as a hole. then just run the anttena cable under the glove box, down to the kick panel and then tuck all the way along the passenger side trim pieces until you can get the cabling into the trunk area. from here you can use the magnet antenna to stick it to the valet key lock on the rear deck or continue outside the trunk lid where you would then use a trim pri bar wraped in a cloth to pull back the rubber around the rear window. continue tucking the cable along there and then mount the antenna on the roof.
Old Dec 28, 2006
Dieselboy's Avatar
Dieselboy is an unknown quantity at this point
I routed...
the way they tell you to mount the antenna on the outside of ther car looks hella gay. i have an oh 5 ex coupe and what I did was route the antenna wire under the carpet to the rear windshield where the ant is (good reception)
I have 2 areas whre i put velcro strip and it looks good...
but now i'm upgrading to the stiletto and it will look even cleaner.
I mostly listen to Howard Stern...I havn't upgraded to HD quality yet...so music sounds like radio poopyness
Old Dec 28, 2006
Rufus's Avatar
I can help you when I get back from Reno on the 2nd...
Old Jan 17, 2007
FALKEN's Avatar
Civicforums Junkie
the headunit needs to be turned up quite a bit when using the unit...must be the FM transmitter
would a SIRIUS FM Direct Adapter help with the audio output?
Old Jan 17, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
^ Which one did you get? If it is one of the P & P ones from Directed then yes, you should get the FM direct piece. It will make a dramatic change in the way the FM modulator works. It is basically a relay that plugs into your cars antenna that switches the FM mod on and off. Also you can go into the Menu Settings and change the Audio Output level...
P.S.. those friggin wheels are HUGE!
Old Jan 17, 2007
FALKEN's Avatar
Civicforums Junkie
i got the Starmate 4...the audio output level on the unit is 100%
if i bought this, would it eliminate the extreme volume from the radio when the unit is turned off?
also, would i still need to use the external magnetic antenna?
Old Jan 17, 2007
Alpha 5's Avatar
Lucky bastard.
Old Jan 17, 2007
Taffy's Avatar
Damn the site is all jacked up!!
Anyway to answer your questions...The FM Direct Adapter would eliminate all noise and interference from the FM Frequency that you are using for Sirius. As far as the "extreme volume" you speak of...the distortion will be eliminated so you won't have to turn the volume up as loud as before.
Yes you still need to mount the external magnetic antenna. On the trunk, outside in the middle would be the best spot without looking gay.
As far as mounting the Starmate, one of the members on here did a sweet install with his Starmate using the pocket underneath the aftermarket headunit. But since you have an '01, you could put it right next to the power outlet where the fog switch should be. It would look sweet right there. Just use the bracket that it comes with and attance soem screws to the console piece so that it will never fall off..
lemme see if I can find that other guy's thread...
AHHH SWEET here it is...
https://www.civicforums.com/forums/2...armate+install
Old Jan 18, 2007
spoonEM's Avatar
omgwtfbbq mod.
Just buy one of those universal cup holder kits...or if you dont mind a couple holes, get one of the universal brackets.
Old Mar 4, 2007
FALKEN's Avatar
Civicforums Junkie
i installed the Sirius in a better location...the only thing that i may change is to try and hide the wires a little more
opinions?
Old Mar 4, 2007
Taffy's Avatar
Looks sweet. yeah hide the wires
Where did you put the antenna?
Old Mar 4, 2007
FALKEN's Avatar
Civicforums Junkie
Old Mar 5, 2007
Taffy's Avatar
When I had an old school Sirius tuner I mounted the antenna on the rear deck and it got perfect reception. Only sometimes would it cut out. I put it there so it wasn't obvious that I had satellite, but I knew I had it. But then again that was an older unit so they might have changed the way the new ones work, and putting the antenna on the inside might not work.
Old Mar 5, 2007
TRIZ's Avatar
May be a little to late for you, but you could do something like this to mount it if you dont like the current location. (image is hyperlinked to thread)
Old Mar 11, 2007
CecDogsVTEC's Avatar
Member
CecDogsVTEC is an unknown quantity at this point
Here's mine....
Old Mar 11, 2007
TRIZ's Avatar
^ suction cups?
Old Mar 11, 2007
Member
Yes.
Old Mar 11, 2007
Member
Sorry the pics are so big, here is a closer look....
mylx
South
Dec 27, 2001 07:25 AM
antidote11
Dec 21, 2001 05:14 PM
