Constant rumbling coming from subs
Old Dec 24, 2006
Nas0827's Avatar
Nas0827 is an unknown quantity at this point
I have the panasonic double din and recently i noticed a constant rumbling coming from my subs. Any ideas? grounds are good and doesnt seem to be the rcas
Old Dec 24, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
How does it not seem to be the RCA's? Try unplugging them from the amp and see if the subs still rumble. If they do, you know its either: Power, GND, Remote lead (this actually happens!), or the amp itself. If the RCA's are causing it, try eliminating the RMT lead next by jumping from the + to the RMT in. Still there or not? If it is, PWR and GND problems are a little difficult to troubleshoot, so try swapping out amps or bringing yours to a shop to have them bench test it.
Old Dec 24, 2006
free_refil's Avatar
Also, does this rumble change in frequency with your engine speed?
Old Dec 24, 2006
Black-EM2's Avatar
Black-EM2 is an unknown quantity at this point
i just had a kicker amp do this to me...drained my battery and all.. it just would not stop..even with car off...so i took it to the people who sold me the amp .. and they told me it was defective.. so they gave me another one free.
Old Dec 24, 2006
Nas0827's Avatar
I tried switching out the rcas and still same problem, when i unplug them the noise goes away. I pluged my ipod into the rca jacks and sounded fine. Not exactly sure what you mean with the remote lead.
Old Dec 25, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
You should try a new ground, 12V, and maybe even accessory at the deck. If you unplug the RCAs at the deck (but not at the amp) does the sound go away?? If it does it's an issue with the panasonic unit (or it's install). If the sound doesn't go away with RCAs unplugged from the deck, it's RCA routing.
Old Dec 25, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
make sure your amp is set up to oinly pass low frequencies. probably wont fix it but maybe
Old Dec 25, 2006
Nas0827's Avatar
set to lpf and sound goes away when unplugged from either point
Old Dec 25, 2006
free_refil's Avatar
So you set your deck's output to LPF? Or the amps?
Old Dec 25, 2006
This leads me to believe the problem is with the deck. Upgrade connections (especially ground) as I mentioned and maybe even bench test the deck. Try swapping the pre-out as well, if you're on sub try rear and see if the noise goes away at all.
Old Dec 25, 2006
Nas0827's Avatar
What do you mean upgrade the ground? I plugged the rcas in the rear and does the same thing
Old Dec 25, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
sounds like you have a bare wire or a wire shorting out somewhere go through and just re track your wires and make sure all is tight and not touching metal...
Old Dec 25, 2006
Nas0827's Avatar
rewired the entire headunit, still nothing
Old Dec 25, 2006
jeffsta17's Avatar
so even when you mute the deck the rumbling persists? Im not dissing you but make sure the RCA's are hooked up right, like right and left is same on the deck and the amp. Again you probably have that done already but it is probably something stupid. Also try going through your EQ or bass boost on your deck. Also check you amp and adjust the bass boost there. Start at 0 for everthing and maybe it will stop
Old Dec 25, 2006
Nas0827's Avatar
EVERYTHING is hooked up correctly, when i mute it it goes away. I have had this set up for a little while and no problems. Havent changed the amp subs connections etc. This came out of no where the other day and have no idea what it could be
Old Dec 25, 2006
jeffsta17's Avatar
is it coming out of both subs? Maybe one of your subs unloaded/overexerted. Maybe its voice coil popped. try disconnecting one sub at a time. Thats if you have more then one sub.
Old Dec 25, 2006
Nas0827's Avatar
I have 2 and both do it. Pretty sure its not that because i hooked my ipod up to them and it didnt do it
Old Dec 25, 2006
jeffsta17's Avatar
did u hook the ipod up through the deck? does it only rumble on certain inputs?
Old Dec 25, 2006
Nas0827's Avatar
no, ran rcas straight from ipod to amp, used the cord with the headphone jack on one end and rcas on other
Old Dec 25, 2006
Nas0827's Avatar
rumbles on all.
Old Dec 25, 2006
jeffsta17's Avatar
Id say its definately the deck. sorry i wasnt more helpful
Old Dec 25, 2006
Upgrade ground means to run your own ground wire from the deck to a bare piece of metal connected to the chassis. Scrape off all the paint and screw it in real well.
Starting to sound more and more like a problem with the unit.
Old Dec 26, 2006
Nas0827's Avatar
thats what im thinkin. thanks
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
ej8
Apr 13, 2015 06:36 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
