SE Bezel navigation mounting problem
Old Dec 21, 2006
export05exSE's Avatar
export05exSE is an unknown quantity at this point
Arrow SE Bezel navigation mounting problem
Well, I just bought a Pioneer Avic D1 navigation and am still in the 'ordering parts' process of putting it in a 2005 Special Edition. Up until this morning I thought all radio bezels from 2001 - 2005 were all the same.
Pioneer Electronics - In-Dash Navigation
This has 3 pictures of how flush I want my screen to be, however this can only happen if I buy the 2001 - 2005 NOT SE bezel and then get a double-din dash kit from metraonline.com apparentally. I would like to do some sort of custom work; however, here's what another person did, but I want it to sit flush with everything like in the Pioneer pictures.
This is the bezel that I need since, as you can see, has a slight lip around the perimeter of the housing so stuff sits more flush:
Whereas the Special Edition has no lip to hold anything level:
Well, I guess where I am going with this is that I am looking to either:
(1) trade bezels for the non-special edition one
(2) buy one if someone has one they aren't using
(3) find if anyone knows of a mount I can use on the SE bezel?
Thank you guys for your time and I look forward to hearing from you.
-matt
Duck916@comcast.net
Old Dec 21, 2006
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
why not try ISO mounting it?
Old Dec 21, 2006
*confused* what is ISO mounting and do you have a picture of something done like that?
Old Aug 30, 2008
arabianknight's Avatar
arabianknight is an unknown quantity at this point
Re: SE Bezel navigation mounting problem
export05exSE, have you had any luck with your navigation setup. i have an ex se and my gps unit isn't flush with the radio bezel. any advice?
Old Sep 6, 2008
export05exse, i just ordered the dash trim for the 2005 civic ex coupe. i have a ex se also but i put the climate control part for the regular civics and it fit perfectly. then i got the trim kit for the double din radios from metra and it looks great. i'll have pictures up shortly
Old Sep 6, 2008
refer to the attached image. you want part number 11 for your ex se dashboard.
i bought my part from here:
www.hondapartsdeals.com
even though i have a 2005 civic ex se, i put my vehicle as 2005 civic ex. the part was 40 dollars but i figured it was worth it, so i bought it and it looks great.
the exact honda part number is:
77250-S5A-A11ZC
the trim around the radio you can get from metra. heres the link:
http://www.metraonline.com/products.aspx
the metra part numbers are either 99-7865 or 95-7899
I'm guessing you want your final look to be like this:
minus the peach color.
hope this helps.
Old Sep 6, 2008
Rufus's Avatar
Mold it....
cdt12271
Apr 23, 2015 11:36 AM
ZSKCivic01
Jan 5, 2002 12:15 AM
TypeR2k1Civic
Dec 15, 2001 10:10 AM
