largest space for sub box?
Old Dec 13, 2006
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
Question largest space for sub box?
im trying to figure out the measurements for my new custom built box for 2 12's but still unsure of whats the largest i can go. i measured my trunk and i estimated around 33" width/16" tall/17" depth. im sure i could have more depth but im afriad that it'll have a hard time getting into the trunk considering it has a small opening.
id like to know if anyone here has fitted a big sub box in their trunk? what ere the dimensions? perferably a coupe. hopefully someone could answer so i can give the box builder the exact dimensions im working with. would hate to find out the box doesnt fit
Old Dec 13, 2006
so i just remember i had this in my trunk before:
by those dimensions, you think i should do 33" wide/15" tall/20" deep for 2 JLw6v2's tuned to 32hz, which will leave me about 1.9 cubes(?) per sub? im looking for maxium loudness but still retain good SQ.
Old Dec 13, 2006
kronickz's Avatar
kronickz is an unknown quantity at this point
the height can't be 16" because it will wont fit and the width needs to be 32" and the most depth you can go is 32". I know because i built a box that was 16" in height and it didn't fit. My box messures Width-32", Depth-32", and Height-15" which gave me roughly 7.3 cubic feet. I have my speakers facing up though for 3 15" JL w6's. It's loud but is even louder with an epicenter hooked up. Hopefully that helped you out.
Old Dec 13, 2006
LudlamTheory's Avatar
i boogie for the raindrops
the largest i've made that comes in and out of the trunk is 41 wide, 21 deep, 13 tall
5 cubic feet
it may look like you cant fit it once you make it, but at the right angle, it'll go in
i've made larger, but it lived in the trunk full time
Old Dec 15, 2006
5 cubic feet
thats a pretty big box. was this a coupe or sedan? got any pics?
Old Dec 15, 2006
sedan, but the trunk is the same on both
nope, have no digital camera
like i said, i had a 6 cube box for 3 12's before
but he was built in the trunk to be permanent
Old Dec 15, 2006
goddamn...guessing you mounted your amps on the backseat? how would you go about to remove the box?
Old Dec 15, 2006
kuNhoHan's Avatar
kuNhoHan will become famous soon enough
pull the seat down
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
krazykoncepts
Sep 8, 2015 09:02 PM
