HELP!! Tail light and dash illumination went out after install.
Old Dec 11, 2006
  #31
Mralbino's Avatar
Mralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to beholdMralbino is a splendid one to behold
^^^^^^ Everybody give this guy a Round of Applause , Guy.... YOU WERE RIGHT!!! You knew exactly what you were talking about!! Anyways... Im glad you got your **** working, it was my pleasure to help out.
Old Dec 11, 2006
  #32
Mralbino's Avatar
Originally Posted by cj2185
That was my last resort guy and thats what i did cuz i tested my cluster and everything. Changed my cluster and everything is fine, that was my prob. + plus right after i installed my headunit and put it on, some smoke came out of the cluster.
Well.... you and the other guy had 2 completely different problems, i had the same problem as he did, next time read everybodys replys and know what your talking about before you make a fool out of yourself.
Old Dec 11, 2006
  #33
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
what kind of car is this?
Old Dec 11, 2006
  #34
Interlagos Fire's Avatar
Interlagos Fire is an unknown quantity at this point
It's a 05 Civic Sedan.
Thanks again, Mralbino and Hondercivic
Old Dec 11, 2006
  #35
Civicman1988's Avatar
check ur fuses.
Old Dec 11, 2006
  #36
well, sounds like you got your answer. reason i asked it some 96-98 civics lose some of their lighting when a new deck is installed. reason is the illumination circuit goes though the radio. not all of them, but the ones with 2 harnesses on the factory radio
Old Dec 11, 2006
  #37
cj2185's Avatar
cj2185 is an unknown quantity at this point
Fist of all i didn't make a fool of myself, i was just trying to help the guy thinking the same thing had happened to him.
Old Dec 12, 2006
  #38
Mralbino's Avatar
This same situation happened to me when i installed my kenwood deck. For the lights, check the fuses and for the illumination lights; well your gonna have to get a new cluster cuz it controls the illumination lights. I figured that out when i took my car to honda to get it checked. it cost me $100 for them to tell me that my cluster lights which also controls the illumination was busted. The speedometer and all the other meters still work, but you wont have any illumination at night.
And no you don't need a new cluster, he just needs to check his fuses if he can find them. And if it blows again than he has a short somewhere, that either has to do with a wire touching metal or those orange wires that arn't supposed to be connected.
I did change the fuse. the exterior lights were working. the cluster controls the illumination and if the cluster don't work, the illumination wont either.
And i brought it to honda and they said dat the cluster was messed up.
Leave the orange wires alone.
Originally Posted by Interlagos Fire
Yes they are working, AND PROBLEM IS SOLVED!!!!!!!!!
and yes, no cluster is required, thank god! but thanks for trying to help anyway.
To everyone that's helped, THANKS!!!!!! rep to everyone of you!
7thgencivic ROCKS!
P.S. it is the orange wires that's the culprit, I separated the two with individual caps and electric taped them up the a** to prevent short, and did the same thing with the remote wire too, eventho it didn't seem to be the problem, but just to play it safe.
^^ It looks like you made a fool out of yourself because you were arguing with me and demanding him to leave the orange wires alone. But anyways i don't care, he solved the problem thats all that matters. But anyways... IM A
Poopies
Apr 20, 2017 11:36 PM
SSMatey
Apr 13, 2015 06:09 PM
shaejb15
Apr 12, 2015 11:38 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
