tweeters
Old Dec 4, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
tweeters
ok, so i am planning on putting some kick panels in my car, but i would also like to put some tweeters in car also, i know i want some in the c pillars, but up front i dont know if i want them in the a pillars, or the mirror thingy, which is the bset to go with?
Old Dec 4, 2006
burke420's Avatar
The World Is Yours!
youll hear the music real well in the sail panel. dont get them in the a-pillar. or b pillar. go with the sail and the rear c pillar, is for the purpose only to increase highs, but another tweeter in a kick panle should fix that..
Old Dec 4, 2006
and the sail panel is where the black part of the mirror is on the inside, right?
Old Dec 4, 2006
burke420's Avatar
The World Is Yours!
yeah. get the tweeter panel for a cleaner install
Old Dec 4, 2006
ok cool thanks, where might i get one of those at. and secondly, how would i wire those into my stereo? i ahd mine profesionally, should i have that done again?
Old Dec 4, 2006
Burke420 +rep1
Old Dec 5, 2006
drivlikustoleit's Avatar
drivlikustoleit is an unknown quantity at this point
Yeah I had questions about this too... I have tweeters from my old mercury sable (took those babys out right before handing the car over to the dealer ) Will those fit in the sail panel, or are there specific ones you need to get. Is there a sail panel you can get from Honda that has the holes in it already? I too was wondering how you would go about wiring them into the radio.
Old Dec 5, 2006
burke420's Avatar
The World Is Yours!
if you have stock tweeters, use the stock tweeter harness, but if you dont, make sure that the tweeters come with a crossover. my JLs did. and most component systems have a crossover for that reason. but i say go with a sail panel, it's for 1" speakers, but i had to dremmel the hole to fit my tweeter. but i love it now!
Old Dec 5, 2006
Alright this is what my tweeter looks like, stock in a mercury sable. So I still have the connector on it as you can see... obviously I'm going to have to cut that off and splice the wires... but into what I still don't understand. I don't know what you mean by most component systems having a crossover. Also, am I going to have to trim off the outer rim where the holes are for fastening it to the car, or just reuse them for this case. Caveman talk for me... I'm not good with electronics. Thanks.
Old Dec 5, 2006
burke420's Avatar
The World Is Yours!
strange looking tweeter. but imo, if you go with one from http://www.onlinecarstereo.com
they have the JL tweeter i bought. good stuff! and you can see the if you use that stock speaker, itll prolly transfer bass trough it too. you dont need that! the JL's max out at like 75 watts i think or thats the rms. but go with somethat have this small crosser, it's the size of a AA battery. it is a bass blocker. and you can hook it up through the stock wires.
Old Dec 5, 2006
so how much did you jls cost? and did u just cut the hole in the sail panel, or did u buy a sail panel seperatey?
Old Dec 6, 2006
I think that might be what that piece in the middle of the wires is. I took off the foam that's covering it after I read this post and theres something in there that looks like a AA battery with some metal coil coming off of it, and something else right next to it that looks like a AAA battery... bass blocker? If so, would I just cut off that conector, and splice those two wires directly into the speaker itself?
Old Dec 7, 2006
Scott Civic's Avatar
Racism sucks, just like your Mom...
Scott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of light
Anyone have a diagram or a link to somewhere that would show where each of the pillars are and what their names are?
Old Dec 8, 2006
Not me... this site is my resource for just about everything.
Old Dec 18, 2006
the a-pillars are the pillars that hold in the windshield, the pillars up front. the b-pillars are the ones that are right y tour head in the front seat, or the middle pillars, the c-pillars are the pillars that hold in the back window.
Old Dec 18, 2006
Rufus's Avatar
I run glassed kickpanels with a 6.5 in the kicks and a silk dome tweet in the kicks (nothing in the doors at all). I also run another set of alum tweets in the a-pillar that face each other. Alum are bright and work well off axis. You don't need anything in the c-pillar. I run two 6.5's with no tweets as rear fill. If you set up your front stage well enough you don't even need a rear fill except for people who may ride in the back. Seriously.
Old Dec 18, 2006
Ok. Thanks!
Old Dec 18, 2006
Alpha 5's Avatar
Rufus is on the ball, I straight up agree 100%. Check out my profile I know car audio.
Old Dec 18, 2006
Rufus's Avatar
I posted pics in Members rides under Rufus' Photoshoot...
take a peek for ideas..
Old Dec 18, 2006
Alpha 5's Avatar
This is a tweeter thread and there are no pics of your tweets.
Old Dec 18, 2006
LudlamTheory's Avatar
i boogie for the raindrops
your profile indicates you really don't know much about audio
Old Dec 18, 2006
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
i put my Infinity tweets in the sail panels. just used a 1.75" hole saw.
oh, i had the honda sails with the tweeter in them.
I'll take pics tonight cause they look sweet
Old Dec 19, 2006
sweet do it, i would really like to see that. rufus, i checked out your pics, i like the looks of the setup, just not sure if i have enough to do it, with all of my other plans.
Old Dec 19, 2006
Alpha 5's Avatar
I have worked in the car audio field for many years and done thousands of installs. I have done all my own work and by the amount of electronics in my ride, I would say I am well qualified to say just about anything regarding the field.
Old Dec 20, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
^^^ from just your profile it doesnt make u seem like the know all, ive done what you have in my car, and i havent worked in the industry yet. Anyways im not trying to be a dick im just saying that your profile doesnt make you a bad *** installer
Old Dec 20, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
Stick with them in just the c-pillar..imo
Old Dec 20, 2006
Rufus's Avatar
lol the c-pillar? Could they be any more OFF axis?
Old Dec 20, 2006
Alpha 5's Avatar
^^^^^ C-pillar would be the WORST place to put them. Just think when you go to a concert do you stand facing the stage with the sound in front of you or do you have your back to it? Subs are non directional that is why the trunk is a good place for them, but everything else is directional so you want it in front of you. Well at least I do.
Old Dec 20, 2006
just the equipment you picked alone tells me a lot
Old Dec 21, 2006
Good point!
