!!!Project Audio!!! HELP HELP
Old Nov 28, 2006
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
Do you know how when u get into a very xpensive cars and the audio system is nice clean and bassy W/O a subwoofer!
so im trying to achieve this in my coupe civic. so i did some research, and only component speakers can create this bass!
im lookin at the alpine type R components w/ the alpine 4 channels.
BUT im open for other suggestions
money is kinda of lmiited at the most 1000$
Old Nov 28, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
huh?
Old Nov 28, 2006
dabflyboy's Avatar
dabflyboy is an unknown quantity at this point
why no subs?
Old Nov 28, 2006
Originally Posted by christmaspie
huh?
becuase it can create this bass that i want with out distortion of the highs...normal speakers get all distor when the bass is high
Old Nov 28, 2006
Originally Posted by dabflyboy
why no subs?
the main reason is the bass from the sub is too much for me. plus i dont listen to rap.
Old Nov 28, 2006
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
Just get some subs if all you want is bass.
Old Nov 28, 2006
djdust12's Avatar
djdust12 is an unknown quantity at this point
If you don't get it solved from here, try calling Crutchfield. Those guys are really good and friendly. If you don't want to buy from them, you can just take their ideas or suggestions and buy somewhere else - http://www.crutchfield.com
Old Nov 28, 2006
buckshizzo's Avatar
Just get components and amp it up, you'll get that clean sound with bass your looking for. Bostons or infinity are good speakers that will give you that bass your looking for.
Old Nov 29, 2006
LudlamTheory's Avatar
i boogie for the raindrops
ooooooooook
so lets start from the beginning.
in order to have proper low frequency extension in our cars, without the use of a subwoofer, a few things are required:
1 - deaden the crap out of the doors
2 - a speaker with proper low frequency extension must be used
3 - proper power must be provided
First of all, knock on the doors of a civic, inside and out, then go knock on the doors of any european car. first thing you'll notice is that ours sounds like a metal trash can, while most european sedans will sound a lot more solid, a more thud-like sound. this is because these cars are deadened properly and the metal used is a lot thicker.
also
these doors are usually sealed up pretty damn well, whereas ours have big gaps in them
so
to remedy this, we have sound deadener. now you dont have to go buy dynamat extreme and waste your hard earned dollars, try www.raamaudio.com
they sell stuff just as good for a fraction of the cost.
one roll is PLENTY to do both doors and the rear deck.
this will create the proper enclosure for the speakers, and the proper solid mounting location
this alone will improve the midbass and bass output from any set of speakers.
type r's work pretty well for the price
there are a few others out there that would probably do you well also
Old Nov 29, 2006
This man knows what he's talking about. I'd look in this direction, turns out the installation is more important than the speakers you're running.
Old Nov 29, 2006
Forrest01EX's Avatar
Forrest01EX is an unknown quantity at this point
hey, definitely i would go with components, i actually deadened my doors a lot and added som 6 1/2" mids (they needed MDF rings to clear the mounting depth in the door.) and some 1 inch tweets at the base of the A-pillar.. i bought some components from Elemental Designs.. they are a small company but they hand build all their speakers.. they have great prices, package deals, and they have cheap deadener too.. good luck.. let us know what the end product sounds like..
Old Nov 29, 2006
HAH!
elemental knows NOTHING about hand building their own speakers
pretty good speakers for the price, but they dont touch them. cdt builds all their speakers, tangband builds their subs, and i cant rememeber who, but another company builds their amps
Old Nov 29, 2006
hwt101's Avatar
hwt101 is an unknown quantity at this point
Dynomat your entire car and your stock speakers will improve almost 100%, but most of those stock "bassy systems" are in nicer cars that already have sound deading material, and they usually have like 6 to 8 speaker systems, oh and i dont listen to much rap and i have a killer system ( thats why they make 8's)
Old Nov 29, 2006
currently i have infinity kappa 3-ways speakers amped w/ 60rms going into each.
and i cant seem to tune the amp to produce the sound i want.
im gonna try a different amp w/ more power (lookin at the alpine 75rms/each)
Old Nov 29, 2006
sleekcivic2004's Avatar
sleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nice
This is what I was going to suggest would be the best route. You should have no problem getting sound deadener, an amp, and an 8-inch sub for under a grand that you would be happy with. Actually, for enough sound deadener for all the important areas of your car, an amp, an 8-inch sub, and for installation of the audio components (wiring, amp, sub) you should be able to stay around 500 bucks. Now you will need to get a box for the sub and as far as that goes the could range from $50-$500 bucks depending on what you want.
Old Nov 30, 2006
thewood22style's Avatar
thewood22style is an unknown quantity at this point
Sound deadener definatly helps in the doors.
Old Nov 30, 2006
That company that hand builds their amps would be Zapco. But on topic, from my experience I would say that for a good price the Polk MOMO series component speakers were a great set. They sound really crisp and have the bass that you are looking for if installed right.
Old Dec 9, 2006
ok i just ordered 06 alpine 4 ch amp w/ 70rms....gonna use this to tune my kappas...hopefully this will come out better
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ricer_em2
May 11, 2016 08:09 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
