Moisture Barrier?
Old Mar 18, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
Moisture Barrier?
In the doors, there's the white plastic, which i'm assuming is for a moistrure barrier between the door and the paneling, well, it shouldn't be a bid deal if i take all that out right? the only thing that should be vibrating in the door is the speaker....
Andy
Old Mar 18, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
why you takin it out? just dynamat over it..gets rid of all raddle. or take it off and replace it with dynamat
Old Mar 18, 2002
mohawkboom's Avatar
Yes it is a big deal.. Beleive it or the inside of your door sees ALOT of moisture.. everytime it rains water leeks into your door.. DOn't remove it... if you do..replace it with sound deadening mat.. NOT DYNAMAT... it's agreat product.. but there's better out there for much less $$$$$$
Check out the RAAM Mat deal we have on here.. or also check out www.b-quiet.com
Old Mar 18, 2002
DogstyleEX's Avatar
Ok, so i should either put sound deadening mat over it, or take it off and cover the whole door with it.. will the moisture affect the sound deadening material at all? I'm prolly gonna cut it all out and replace it with something like the RAAM stuff... is this even a good idea? i mean i can hear the plastic behind the door rattling.. it drives me nuts.. Thanks
Andy
General DIY
Sep 25, 2015 08:02 PM
eebing
Sep 12, 2015 05:35 AM
ZSKCivic01
Mar 5, 2004 10:56 AM
