Help with a trunk problem.
Old Nov 5, 2006
StoneKotr's Avatar
StoneKotr is an unknown quantity at this point
Hello,
I just got a CIVIC DX 2003 and of course installed a nice sound system in there with a subwoofer. The problem is, my trunk doesn't seem to like it. It literally wants to fall apart... And it doesn't make a nice sound, it's acceptable inside the car, but outside it really makes an awful sound.
I can assure you that it is not the license plate shaking, but the zone behind the plate. I've tried to remove just the license plate and it was still the same weird sound.
I don't know if you guys have some solutions for that problem.
Old Nov 5, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
dynamat a little, use search.
Old Nov 6, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
if you lower the mount that the trunk latch latches too it can solve your problem maybe. Look in your trunk right at the edge and you will see a Metal "hook" looking thing that the trunk lid latches to, remove the bolts and slide it down a lil bit and then tighten it back up and test to see if the trunk closes, if not move it back up a lil bit.
Old Nov 6, 2006
jeffsta17's Avatar
also maybe put some dynamat on the back of your liscense plate it should stop that from rattling too.
Old Nov 6, 2006
Rudy's Avatar
Rudy is an unknown quantity at this point
Sound deadener is your friend here. Tighten the latch as described then sound deaden the entire trunk. You definitely want to hit the entire vertical area i the back where the tag is attached and the part of the trunk below that.
Old Nov 6, 2006
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
my trunk springs will resonate..it's an awful sounding thing...
Old Nov 6, 2006
Rudy's Avatar
Time to replace them with shocks. Easy to do and much nicer.
Old Nov 26, 2006
jovenilleb's Avatar
jovenilleb has a little shameless behaviour in the past
Bro, Same thing happened to my car, I put 2x 12" sub infinity subs with 1800 amp,When I put it to sound to level 15, my trunk rattles same with the car at my side but it sounds terrible.Anyway I put Dynamat on all the hole in my truck, I cut it and all that that hook to close the trunk.That hole is the main one, Put dynamat or something to cover it.the rattles will go away. If you cant understand my english which I suck so bad, PM me and I will post the pic for you man. later
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Skunkone
Sep 24, 2015 04:38 PM
