pictures
Old Oct 20, 2006
hwt101's Avatar
hwt101 is an unknown quantity at this point
pictures
got the pics up of my set up, well the trunk any ways, www.lakesideaudio.com go to installs and its the 01 civic
Old Oct 20, 2006
skoot's Avatar
skoot is an unknown quantity at this point
How heavy is all that?...ballpark figure
Old Oct 20, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
http://www.lakesideaudio.com/index.p...mid=2&catid=20
Old Oct 20, 2006
hwt101's Avatar
the subs weight is 17lbs a piece the box is probably 15lbs, and the front panel is probably 5lbs ( its not 1 soild piece, i can still get to my spare), and the amps arent much.
Old Oct 20, 2006
flipmoderacer02's Avatar
looks good
Old Oct 20, 2006
hwt101's Avatar
thanks, doesnt sound to bad either, im JL all the way down to my wiring, w7's, zr's, and slash's
Old Oct 21, 2006
Str8UpCivic's Avatar
Tire Spin
Str8UpCivic will become famous soon enough
looks good.
Old Oct 22, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
looks good. You're in the houston area right?
Old Oct 22, 2006
hwt101's Avatar
yep, im the one that offered to let you here what the ZR's sound like.
Old Oct 22, 2006
thefever's Avatar
I need a drop
yeah, yeah. Do you work at that lakeside place? It looks legit, I may have to drive there and check it out.
Old Oct 22, 2006
hwt101's Avatar
no i dont work there, although i am there alot, and yes they are very legit if you head out there tell them hunter sent you
Old Oct 22, 2006
thefever's Avatar
I need a drop
will do. I'll probably be up by pearland near thanksgiving. I'll most likely swing by there then, maybe I'll have the cash to pick up some components. Finally.
Old Oct 30, 2006
hwt101's Avatar
You still headed this way in Nov?
Old Oct 30, 2006
estebomb_ftw's Avatar
looks good bro, i bet it bumps.
Old Oct 30, 2006
hwt101's Avatar
yeah it sounds alright. where you located at ill let you hear it if your near
Old Oct 30, 2006
thefever's Avatar
I need a drop
maybe so. Maybe a little later. I need to come across some money here pretty soon. I may be up near San Jacinto sometime soon.
Old Oct 30, 2006
SaTx.
Old Oct 30, 2006
hwt101's Avatar
San Antonio? i might be up in that area in the next couple of weeks visiting my g/p's
Old Nov 7, 2006
hwt101's Avatar
i got the 2 white cold cathodes hooked up, they look good
HondaGuy7
Feb 22, 2016 01:00 PM
Shadowbandit
Wheels and Tires
Sep 16, 2015 09:34 PM
EM2661
Sep 11, 2015 06:01 PM
khatib
Sep 9, 2015 10:50 PM
beantech
Sep 6, 2015 01:46 AM
