vtech light help!!!
Old Oct 18, 2006
jdmchink21's Avatar
jdmchink21 is an unknown quantity at this point
vtech light help!!!
i hooked up an LED light to find out when vtech kicks in...i tapped into the green wire with the yellow stripe...and i grounded the other wire...it says it has a built in resistor...and yes i do have an EX! please help!!!
Old Oct 18, 2006
sl33pyriceboi's Avatar
first off... its "Vtec"
andd stands for "Variable Valve Timing and Lift Electronic Control"
and second, that wire could hav a constant power but not an engaging vtec signal....its different, you cant just tap into it like that...
Old Oct 18, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
If you search you will find a thread that has to do with this..
Old Oct 18, 2006
lxcivic2k1's Avatar
Why do you need to know when Vtec kicks in? I don't get why ppl want to know since it really doesn't do much on 7th gens, but mine doesn't even have it
Old Oct 18, 2006
genexrocket's Avatar
seriously it's not worth it, vtec engages at a pretty low rpm for d17s around 2.5-3k or something like that, so basically the light will almost be constantly on, it'll only annoy you, and you'll end up taking it out and have to deal with a hole in your dash....imo it's only worth it for type-r's, s2000's, etc.. but then again, you don't need a light to tell you when vtec kicks in for those cars
Old Oct 18, 2006
jdmchink21's Avatar
i kno i spelled it wrong...i was bored so i wanted to try this...does anyone kno wuts going on? should have i bought the resistor seperate from the led?
Old Oct 18, 2006
dont do that it messes up stuff
Old Oct 18, 2006
+1
man.....if u wanna know when vtec kicks in, get a V2....or some sort of intake...
you can hear when vtec kicks in because the tone of ur engine gets alot deeper..
Old Oct 18, 2006
I say do it, then dont come crying to us when stuff messes up! A simple search would have net'ed you an answer that you would have liked.. but nooo.
Old Oct 21, 2006
82801BA's Avatar
82801BA is an unknown quantity at this point
And don't hope for VTEC to kick in when you are at Neautral (M)/Parking (A)
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
lildoo
May 9, 2015 09:44 AM
vtechcivic
Apr 21, 2015 07:11 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
