Matching up the wires
Old Sep 19, 2006
rchoo's Avatar
rchoo is an unknown quantity at this point
I have an '05 ex coupe, and I was trying to tap into something with 12v for a booty call. Instead of going through the battery like the DIY insisted, there was mention that it could be cleaner from the radio 12v or the cigarette lighter? How can I distinguish which cable to tap into?
Old Sep 20, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
what do you want to power with that? need more info, depending on what you want to do and what you want to power, anythings possible, ask and we will help you out
Old Sep 24, 2006
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
i have the same thing on my car. all i did was hook it up straight to the batt so that you could use it even when the car is off.
and for tapping the wire just tap from inside using the fuse box.
spyder13
Jul 31, 2015 06:31 PM
sch2cm
Jul 21, 2015 09:58 PM
estes53
Jul 20, 2015 10:43 PM
robbie374
Jul 7, 2015 02:56 AM
