PROBLEMS!!!! Need Help!!
Old Aug 21, 2006
thewood22style's Avatar
thewood22style is an unknown quantity at this point
Angry PROBLEMS!!!! Need Help!!
So I was hooking up some 8" visor monitors to my deck which is Dual. I believe the model # is XDV-8125 (the one with the 2.5" screen) and when I turned my car on the deck didnt turn on. I didnt mess with any of the wires except the rca's. And now my power locks dont work and neither does my keyless entry. My buddy who previously had the deck said when he was first trying to install himself into his car, the same things happened to him but then when he took to have it professionally installed it all worked. I've had the deck for about 6 months now and ive hooked up things to it before but now I dont know what happened. I checked all the fuses and they are fine. If you can please help me in any way I would appreciate it. Oh and my car is an 01' EX Coupe. Thanks
Old Aug 21, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
did you check the underhood fuses?? and you might want to ensure the connector on the back of the deck is secure or maybe a loose wire inside it. If those are both good, i really don't know what to tell you...you might have possibly grounded out a wire/connector somewhere on accident or maybe a wire has cut insulation and shorted to the underside of the dash....it could be any number of things. i suggest starting small and moving toward switching out the deck to ensure the wiring is good.
Old Aug 22, 2006
HondaKorn's Avatar
Life is better with 5lug
backup fuse under the hood?? that's what my problem was....
Old Aug 22, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
does sound like a fuse problem...
Old Aug 22, 2006
Yea thats what I thought too but I totally forgot about the under the hood fuses and that is exactly what it was. Thanks for the help guys I appreciate it.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
