Power Locks Dont Move (barely)
ok so i think it was because when i 1st got my car i was playing with my locks to much so now the locks dont go up or down and if they do it will be a tiny bit but wont lock. Someone tell me why? did it go off track or something?
idk maybe. open the panel and check. my anti-lock mechanism broke, meaning if the driver door is open and you lock the doors, the lock goes down instead of staying up. stupid thing locked me out once with car running. but i havent had problems with them moving up/down when doors are closed.
ok now i need a DIY door panel removal O_O ill do it after work tommorow oh and mr gearbox you wouldnt happen to know about a "tilt alarm" i was reading it somewhere on the forums i forgot where
http://gearbox.shmikx.net/doorpanel.htm
tilt alarm? you mean sensor or whole alarm not sure on that one.
Were you doing this with the doors open or closed? I know on my car, an EX, if the door is open, the door won't lock. It does exactly what you're describing. I guess it's kind of a safety measure, but gets annoying when I forget to lock my car, and I can't have my friend go do it.
Is there an actuator?
My driver side door is doing the same exact thing. When I hit the lock button it didn't go down. Then I put the key in and locked it that way. Then I locked/unlocked it like 5 times with my key and then tried it with the remote again and it worked.... I dont know wtf is going on
Originally Posted by RHCP0801
why did you play with your locks lol? is this your first car with power locks
ive used the locks alot too they should be able to withstand normal use. after the so called safety feature broke, i just cut the ignition wire so they dont auto lock anymore. one time getting locked out is enough for me. oh and my windows are squeaking when i use em.
h4ldol
Jun 3, 2015 03:26 PM
beveragemp
May 25, 2015 07:11 PM
Youshoe
May 22, 2015 09:36 PM
Paul Harsze
May 20, 2015 11:37 AM
