How can I setup an amp in my house :)
Old Mar 11, 2002
guy's Avatar
guy
guy is an unknown quantity at this point
Is this possible? I was thinking I could use some bass in my room [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 11, 2002
Blznweels's Avatar
Blznweels is an unknown quantity at this point
You sure can, go to radio shack, buy a 15V ac\dc adapted ($15 or so), 1 foot of wire and a switch
strip the end of the plug
take the wire cut into 3 equal pieces
take 2 of the wires and connect to the red wire, cut on in half and put switch in-line
connect switch red wire to the remote terminal, and the other red wire to the positive terminal,
connect white wire to ground,
connect your rca's, and subs
your ready to go, when you not listening to your music, just flip the swith cand the amp will turn off.
Old Mar 11, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
lol, too funny. you could also get a deep cycle battery and hook it up to a charger every night an hook it up like normal, but that would cost MUCH more than the converter that he mentioned.
Old Mar 11, 2002
mohawkboom's Avatar
You need a power converter..preferably one a little more powerful than you're amp. a 600 watt a/c - D/c converter run you about $220
Old Mar 11, 2002
Voiceofid's Avatar
End Bringer
just clam down on it with a battery charger [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 11, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
lol@ID. not quite enough current in a battery charger. haa.
Old Mar 12, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Or you could go to your local HOME AUDIO store and buy a powered subwoofer. Just run your RCA's into it and set the gain and frequency on the back. Would seem a lot less complicated, you can usually pick one up fairly enexpensive unless you go crazy with it. I paid $400 for my Klipsch KSW-12 (450 watts)
h4ldol
Apr 24, 2017 08:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
