Visual Audio
Old Mar 11, 2002
microdot's Avatar
microdot is an unknown quantity at this point
Visual Audio
I was wanting to hook up one of the indash pop-out screens. I was wandering if the OEM indash CD changer could be wired to work with the aftermarket deck. Has anyone done this?
Old Mar 11, 2002
mohawkboom's Avatar
It should be possible.. the OEM CD Changer uses an FM Modulator and hooks in through the antenna connection..
Old Mar 11, 2002
avenger's Avatar
avenger is an unknown quantity at this point
is the oem indash changer controlled by the stock HU?
Old Mar 12, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
<< I was wanting to hook up one of the indash pop-out screens. I was wandering if the OEM indash CD changer could be wired to work with the aftermarket deck. Has anyone done this? >>
The only one that MIGHT allow you to control an OEM CD Changer is the Alpine. I'm not sure about the new ones but when I had my '92 Accord it would control certain Alpine changers. I'm not sure if they still do or in what models, but Alpine actually makes/made the head units in most Hondas. As far as the RF Modulator that doesn't allow you to control it with your radio, just listen to it.. but the OEM CD Changer is not an RF Modulator unit.
Here, check out this link, there is a cable that allows you to do it. I'm not sure if this is the right cable because it only lists to 99, but it will get you started Changer Cable
Okay, I'm sorry it is late. You want to use an aftermarket radio to control a factory changer?.. that I do not know!! I was thinking the other way around, factory head unit, aftermarket changer!
Again I think this is my 4th Edit.. Upon further reading I believe I was right in the 1st place only in reverse order. Apparently that same cable will allow the reverse effect, but only with an Alpine (Honda radios use the Alpine protocol) Read Here
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
